@clairelp well that's a full house for me, after everyone here mentioned pipework clipping , fan noise, pumps, auto air vents. Need to listen to experts that install this stuff every day. Glad it's sorted for now.
Nope no luck.we tried setting back again and the defrost cycles came on woke us up. It even was vibrating our bed. I had noticed it doing this before and my husband I didn’t think he believed me till last night.
i will call them back again, as it’s definitely not normal to be vibrating furniture.
I might see if they can turn the buffer off, as this is what is causing the loud unusable noise not the ashp. During the night when it’s doing its anti pipe freeze cycle it uses the vessel and that’s when it’s vibrates the furniture.
To add insult to we also have a pipe come though our ceiling. They said it’s where during install they had leak made ceiling wet and the must have pushed it through. So we now currently have a hole on ceiling playroom. 😩
I also did ask about the anti vibration clips and they said they don’t use them.
@clairelp I did think the solution sounded hopeful, and am disappointed to hear it didn't work. Please keep us updated.
@editor Yes indeed! A great shame as it sounded so hopeful; so I take it the system will be being turned off at night for a few more days. 😒 Hope your installers return soon and find the culprit. Regards, Toodles.
The pipe on that bar looks the prime suspect for a noise issue, should be able to lift slightly to get some insulation in-between pipe and metal bar.
The other part is the auto air vent, just undo the little black (assuming it's closed)
Not sure if this is something @louise-howlett can potentially assist with?
@editor Thanks for the enquiry I'll get my technical buddies to take a look at the photos on this thread. There can be several causes of noise and vibration. We do cover the Bury St Edmunds area.
Commercial Director: R A Brown Heating Services
- 2,152 Topics
- 47.2 K Posts
- 51 Online
- 5,671 Members
I suspected such a discrepancy, but we need to be 100% ...
By cathodeRay , 4 minutes ago
By Majordennisbloodnok , 19 minutes ago
By Toodles , 2 hours ago
The ones shown in March had a tidy-looking base, but it...
By avenir , 4 hours ago
@bontwoody Maybe one for @editor to consider whether a ...
By ChandyKris , 7 hours ago
By Old_Scientist , 8 hours ago
@mars That response surely deserves a nomination for Tu...
By JamesPa , 21 hours ago
Specifying batteries, pv solar etc using ChatGPT
I thought I'd try to use ChatGPT to specify my requirem...
By Tim441 , 22 hours ago
When I interviewed Mitsubishi Electric at Installer ear...
@lucia One look at that protection and the rodents will...
By Toodles , 1 day ago
By Lucia , 1 day ago
What is the Heat Geek Guarantee?
We regularly hear from homeowners who are researching i...
@adamk, interesting point. I’ve not focused much on Hea...
Intelligent Octopus Flux (IOF) Review
I promised @toodles that I would provide an update and ...
@julianc Our solar PV has produced more this August tha...
By Jeff , 3 days ago
By GrahamF , 4 days ago
By cathodeRay , 4 days ago
