App to AroTherm 5kW connectivity
Update: Vaillant support say that the VR92x goes between the wiring centre and the VRC700 using .75 twin core. The diagram in the manual says it goes between the VRC700 ethernet port and the router, which makes a lot more sense to me. The installer wants £390+VAT to do it and isn't sharing how they would do it. Please help! I really don't want to have to go to the cupboard every day to get my consumption data.
I don't know why all my questions and comments are ignored on this forum, so I'll just continue talking to myself.
I just spoke to Vaillant tech today and they said I should get the VR92x and the VRC700 app. By the end of the year I can "upgrade" to the myVaillant app.
Oh well, back to Facebook...
- 2,418 Topics
- 54.8 K Posts
- 333 Online
- 6,098 Members
@mrfield, welcome to the forums. Please go here and ...
By Mars , 34 minutes ago
RE: Daikin Wireless Thermostat
Our Daikin is due to be installed next week. Today i...
By Bash , 1 hour ago
RE: Reliable, easy to use home battery options
Clearly aware we are talking about safety here. But a s...
By Batpred , 1 hour ago
RE: Ecodan Pump Issues… Circulation pump turns off when heat pump compressor turns off
@ashp-bobba Thanks for the reply. Would it not work ...
By Patch321 , 1 hour ago
I did not hear back from the tech team. (Assume they ar...
By swwils , 2 hours ago
RE: How to use my Hanchu battery storage for home without it feeding back into the grid?
Hi. My Hanchu battery system is controlled by the (Lux...
By SKD , 4 hours ago
RE: Installer Fitted 9kW Instead of 11kW Heat Pump and Changed MCS Paperwork - What do I do?
@jamespa thank you again. Apologies I missed you pointi...
By MairiA , 4 hours ago
In the Home Assistant firmware the data points...
By F1p , 15 hours ago
RE: GSHP WOES! Midland based engineer recommendations?
@johnbroome if it is not the pressure in the expansion ...
By ASHP-BOBBA , 16 hours ago
So I hear the export MPAN that UKPN assigned should be ...
By Batpred , 19 hours ago
From what I read, the Solis has a very long list of err...
RE: Ideal HP290 14kW ASHP - how to optimise
Roughly this should cost you £250-£300 per peak month a...
By ASHP-BOBBA , 20 hours ago
RE: New Daikin 11kW Altherma 3M install - is it working as it should?
@toodles Thank you for your input. As the days have got...
By Synthbuilder , 23 hours ago
RE: Fan unit Making terrible noise HELP!!
@gutoffowc Oh no, sorry to hear that, are you in the Ke...
By ASHP-BOBBA , 1 day ago
RE: Sunsynk Whole House Backup Issue
@sheriff-fatman - could you please re-post that in the ...
By Transparent , 1 day ago
RE: Running my new Nibe ASHP efficiently
I didn't. I spent a while manually messing around with ...
By jamieheatpumpnew , 1 day ago
RE: I’m glad the cold spell is over!
I comparison with the 65kWh used above yesterday was on...
By Judith , 1 day ago
I should think so, I thought that pretty much universal...
I'm also inclined to look into how a defrost is actuall...
By cathodeRay , 1 day ago
