12kW Samsung gen 6 ...
17 Users
63 Reactions
70.6 K Views
Posted by: @craig1980
@derek-m outdoor temp remains the same through cycling process at 6.7 degrees
Is that the temperature indicated on the controller?
(@craig1980)
@derek-m yes. It's 6.4 now though.
16698278519545219915257437836709
(@craig1980)
I've just watched the outside temp on the display for the whole 8 min run. It starts at 6.6 degrees then by around 4 mins it's dropped to 6.3 degrees then in the last minute or so it climbs back to 6.6 where it cuts out for 20 seconds but starts again when still on 6.6.
@craig1980
I'm looking for something changing, during the 20 second period, from the heat pump switching off, to it restarting.
Correct me if I am wrong, that your heat pump runs for 8 minutes or so, switches off for 20 seconds, then runs for a further 8 minutes or so, etc. etc.
A further thing that I find quite surprising is how low are the temperatures of your radiators, your home must be very well insulated.
The next test to try would be to change the controller mode from WC to a fixed LWT of say 35C, and see what effect this has on how your heat pump operates, and what changes occur to the radiator temperatures and room temperatures.
(@craig1980)
Yes, that's correct. 8 mins on, 20 seconds off then 8 on ad infinitum. There is no change in the outside temp during the 20 seconds.
I'm not sure if it's that great on insulation. Cavity wall beads, loft insulation, large double glazed windows but heating sits at 18-18.5 all day. Heat pump is on 24-7.
The temperatures measured on your radiators would indicate that there is very little heat energy being transferred into your home.
@craig1980
Try pulling up the 'Indoor Zone Status Information' as shown on page 18 in the manual shown below.
(@craig1980)
I'll be back home shortly so will do that.
(@craig1980)
@derek-m here you go. When running.
20221130 211115
20221130 211100
(@craig1980)
When stopped for 20 seconds
20221130 211208
20221130 211202
@craig1980
Thanks,
Now try monitoring the 'Master Indoor Zone Information', particularly as the 20 second off period ends and the heat pump restarts.
(@craig1980)
20221130 211115
20221130 211100
Page 15 / 32
