EV+ Heat Pump Tarriff
@etchedpixels Absolutely, the 4 pm to 7 pm penalty could make a difference, especially if the house is all electric and use electricity for cooking. Until recently, I didn't even realise that Octopus offers an Eco7 electricity tariff. With that tariff, it's 1.5p cheaper than Cosy during off peak, albeit it's only 7 hours and they are all in a single slot unlike Cosy. Plus there's no penalty during the evening peak slot and the day rate is about 2.5p cheaper than Cosy. This could even work better than Cosy, if you could run the big appliances like dishwasher and the washing machine during the off-peak slot. Having said that home batteries are probably the best option if one can install them coupled with an EV tariff.
My back of the envelope calculations suggest that we could run our whole house that consumes 8000 kWh per annum (including EV and an heat pump) on an average of about 20p even without solar and batteries. It's still more than double what it costs with our solar and battery setup and being on Octopus Go, but the Eco7 option would be considerably cheaper than being on a SVT.
16 * 435 watts PV
13 kWh Growatt battery
1 EV - Mercedes EQB
6 kW Aira Heat Pump
Bosch Induction Hob
Pod Point Solo 3 charger
Posted by: @etchedpixelsI actually think the fix for many people would just be a bigger battery but it's all about timescales and if someone tricked you into a product tied to overpriced vendor specific batteries or not. If you've got the flexibility then big batteries seem to be the winner with an EV tariff, dunno about agile.
Thanks, my impression is also that investing in a larger battery (if you are not tied into an expensive battery system) is currently the best solution for people combining EV with a heatpump.
Hopefully grid storage will be added, enabling new tariffs that can work with small batteries.
Posted by: @tim441Other considerations if adding a battery... do you want EPS? Emergency Power Supply may or may not be important to you. Ideally fully automated for whole home? But like everything it comes at a cost e.g. Tesla Powerwall or similar
I was lucky that I could add EPS for a very reasonable cost, as below. Solax, Sunsynk/Deye and Victron hybrid inverters have similar capabilities.
The key for this type of systems is to use batteries with compatible BMS (in practice, same BMS).
5 days ago
Our journey through Octopus tariffs 2020-2025
12 months ago
12 months ago
2 years ago
Outcome for 2024 - with Agile, ASHP, PV, Batteries, EV
2 years ago
- 2,820 Topics
- 66.9 K Posts
- 2,723 Online
- 7,232 Members
By the same measure we should be insisting that all gas...
By Batpred , 2 hours ago
True but .. because the room is colder dt rad to room i...
By JamesPa , 2 hours ago
Got two or three heat pump quotes that don’t agree? Post them here.
One of the biggest sources of confusion I see on Renewa...
By Mars , 2 hours ago
I do not disagree with the concept of wanting to live a...
By Batpred , 3 hours ago
@singlespeed I am going to put a temperature sensor on ...
By fosterl2 , 4 hours ago
RE: Grant Aerona - Weather Compensation and Schedules
@taffonthetaff Yes, I have now gotten to the bottom of ...
By bontwoody , 5 hours ago
Occasionally our Grant R290 activates all three circuit...
By TaffontheTaff , 5 hours ago
@davec 47kwh for 3 days is very low, compared to what I...
By johnd , 7 hours ago
By JamesPa , 11 hours ago
By Mars , 11 hours ago
Do heat pump defrost cycles impair heat pump efficiency (COP values)?
The short answer is no, as far as I can see from data f...
By cathodeRay , 12 hours ago
By Judith , 1 day ago
