Mitsubishi Ecodan PUHZ-SW120 & EHSC -VM20 on 3 phase power question
Mitsu PUHZ-SW120 & EHSC -VM20
Has anyone any access to power readings when at rest on a 3 phase ASHP?
I have just installed a Shelly 3EM 3 phase Power Monitor and am somewhat surprised that, at rest, the readings are unbalanced at:
Phase A=0; Phase B=11.31; Phase C=106
When producing heat, the readings are much more balanced.
What, if anything does that indicate?
2 x Growatt 7.5kW Batteries
Fronius EV Charger
Kia e- Niro 64kW
- 2,780 Topics
- 65.5 K Posts
- 1,779 Online
- 7,185 Members
There's an interesting gotcha about that. Suppose the...
By bobflux , 2 hours ago
Heat pump branding. Clever, contemporary… or a bit too much?
I came across this page from a Heat Geek heat-loss/desi...
By Mars , 9 hours ago
@jamespa You have to bear in mind that this is a holida...
By Paul1098 , 10 hours ago
By Mars , 10 hours ago
By ian33a , 13 hours ago
I did, indeed, go with the 12 KW Vaillant unit.  ...
By ian33a , 19 hours ago
@olivierm welcome to the forums and finding the right i...
By Mars , 22 hours ago
I’ve had two calibration cycles in the last three month...
By Davesoa , 2 days ago
@editor That's a pity, but thank you for checking. I'l...
By ltron2 , 2 days ago
My fifth heat pump book, Heat Pumps Explained, is out n...
Just furkled Into the parameter menu. Found the master ...
By AgentGeorge , 3 days ago
By Batpred , 4 days ago
