Electrical works for air to air heat pump
Hi All. Some more advice please.
I'm noticing that the people I contact are reluctant to discuss what electrical work they will do. One mentions it in small point but even he seems to somehow ignore my questions when i try to ask about what these added costs are.
It feels like there is little transparency on any of this. The fact that some people aren't even mentioning this is worrying enough as what are they trying to hide?
The reason I'm asking is because one specific company providing quotes provided a clear cost breakdown which included adding a 13a fused spur and a dedicated 16+ connection (but I can only go on a waiting list for them).
I have asked other companies about the electrics since and they ignore my question which I am assuming is intentional and just answer the easy bits.
I have just been in touch with Heatable about their quote, and after dodging the question initially, they stated that they will simply connect a 5.5KW multi split direct to the consumer unit. I don't think i would want to go with them anyway now but was curious to know their process.
Now im starting to think that this sector is a bit of a wild west which isn't properly regulated. Am I right?
I really want air conditioning before summer and there is a significant waiting list everywhere and I'm getting the impression that those that are able to do the work, are doing it quickly whilst cutting corners.
Best, honest advice here will come from @ashp-bobba!
Posted by: @mrkfmNow im starting to think that this sector is a bit of a wild west which isn't properly regulated. Am I right?
Electrical works are well regulated and most installers will get a separate registered electrician in to do for them (because its a separate part of the job). Perhaps thats why they dont mention it, they dont really understand it and anyway its down to the electrician to assess the situation - electrical regulations are not entirely prescriptive; they expect electricians to do professional assessment).
Normal connection for an ASHP is 16A or 32A (depending on ASHP power) dedicated circuit run back to the Consumer unit (as suggested by heatable) with an isolator close to the unit. Most ASHPs will specify a specific type of RCD if one is used, but strictly an RCD is not mandatory for external fixed plant; MCB protection alone is sufficient from a regulatory standpoint unless the manufacture insists on an RCD.
I haven't heard of an ashp connected to a 13A fused spur but, if the current draw is limited to 13A, nor am I aware of any technical reason why it could not be subject to an assessment of circuit loading and the protection arrangements However I may be wrong, there may be a requirement for a dedicated circuit. If there isnt then its plausible at least that an electrician might, with a suitably low capacity unit, consider this route viable particularly given we dont typically put much power on ring mains these days.
Someone may have chapter and verse but its usually not something to worry about as electricians are mostly pretty good
If it draws under 10A sustained and 13A peak you can just plug it into a socket, although the regs strongly favour wiring it in if it's "fixed". Personally for small systems I prefer them not wired in as it makes it easier to stick extra batteries between them and the wall but the regs prefer it for good reason as well so I get into discussions with the electrician 8).
An electrician isn't going to be able to accurately assess the work that is needed until they've actually looked around the property and figured out what the wiring is, what state it is in and what actually connects where (which is often quite different to what the labels on the CU say for an older setup). There are numerous options available and so much of it depends on the exact building and also what you want - a spur off a ring might be fine for 13A but limit the heatpump performance or sizing, equally that might be what you want because you don't want someone trunking stuff, ripping up floors or digging holes in walls.
If that ring turns out to be broken (very common in older UK houses - stupid system that should have been discontinued long ago) then you may not be able to spur off it and so on.
Really it should be looked at well before installation because an electrical installation can range from "sorry mate, unless it's rewired I'm not working on this" to "oh look there's an old 16A radial we can use". However electricians don't do that for free and aircon people don't want to pay electricians to do speculative assessments.
Good afternoon,
Subject to which brand and capacity unit your are installing, some of the smaller systems can be installed via a spur from a local socket with a 13amp water proof isolator next to the unit (Part P wiring code applies) some installers can do this in house, as a rule most 5kW capacity units can go on the spur type power supply as they draw well under 13 amps, a good installer will know how to work out the correct power supplies and how to advise you. If your installers are struggling I would look further afield as there are now many solar and plumbing companies getting into to AC as per your well known named company are only new to AC in recent years so perhaps they had to double check before advising.
If the system is in capacity 6kW and about the power supply usually starts to need to come from the main distribution board, we aways use our sub-contractor electrical company for this or ask the customer if they have their own and give the customer everything they need to get these works done, included in that info would be:
1) Data sheet, running currents, rota lock (Max Draw), MCB, RCBO and Type
2) Route, location of rota isolator, recommended isolator
3) power requirements recommended fuse
I hope this helps
Posted by: @etchedpixelsIf that ring turns out to be broken (very common in older UK houses - stupid system that should have been discontinued long ago) then you may not be able to spur off it and so on.
Some electricians will downrate a broken ring to 20A which is a good solution IMHO. Its also a good solution IMHO if you want to add sockets and, for whatever reason, connecting them 'in the ring' is not feasible. Obviously not great if there are several power appliances on the ring, but many rings have pretty low load since we (more or less) abandoned electric resistance heating and all our devices went low consumption.
As you say lots of variables, (almost) always a solution though. In the limit fit a henley block and bypass the existing CU altogether, then the electrician doesnt have to touch it. I believe some installers do that as standard.
@ashp-bobba Thanks. The fact is that no one has been open and transparent about electrical costs. almost no one mentions it and those that need to add it on seem to mention it in the small print (and these include air conditioning companies that have been going along time)
When I ask companies these questions they ignore my questions. this really annoys me as they should all be upfront about it - particularly if there are extra costs as this is a big investment for anyone buying air conditioning.
i have one company who are able to carry out a site visit and hopefully they will be willing to explain the process in regards to connecting the system and any costs when they come.
Based on what you are all saying though, it seems that every house is different and presumably, as long as I've been given a fixed price including electrical installation, they will cover the costs if its a more costly install and its unlikely that any of them will knowingly install air conditioners that could overload the system..
@mrkfm I think that it is reasonable to expect them to cover the electrical supply if they include it in their fixed price, I would only accept that fixed price if they have been to look and complete a survey so they are aware what is involved in the installation and are confident or as confident as they can be about the costs.
Posted by: @mrkfmits unlikely that any of them will knowingly install air conditioners that could overload the system..
An electrician who signs off work is responsible for it, so if anything electricians are very conservative in what is acceptable. It's got to be by the book and definitely sufficient for the job. An electrician faced with something like an ancient CU and asked to add circuits to it beyond what is safe will simply refuse to do so unless it's all fixed to regs.
agree with above.
I have not had extra costs added when an electrician prices work based on photos or a whatsapp videocall. But getting them in after that estimate is sometimes hit and miss. But then that was woth inverter and battery, not as straightforward as an aircon.
- 2,821 Topics
- 67 K Posts
- 2,276 Online
- 7,240 Members
I think much of this looks beyond the real problem whic...
By EtchedPixels , 3 hours ago
The portable induction hobs will run at a few hundred w...
@jamespa Will do, cheers. The plumber who ca...
By JWilliams89 , 3 hours ago
By IanWilson , 4 hours ago
By MikeH , 4 hours ago
By Mars , 11 hours ago
By cathodeRay , 13 hours ago
By mk1234 , 15 hours ago
You may notice that Mars is advertising a book called '...
By HeyMikey , 2 days ago
@fosterl2 I'm sure it's over simplified as there'...
By Singlespeed , 2 days ago
