Wood burner with ASHP - direct air?
Hello all, first post here and a question
Doing a full retrofit on new house. Getting ASHP installed later this year but in the meantime preparing wood burning stove.
What are your experiences or opinions about benefit of direct air input for the stove? Was thinking to install air input from subfloor void near external vent.
House will be well insulated but far from air-tight. But considering direct air to avoid cold air being drawn into heat-pump warmed house when stove is on.
Worth it?
Thanks all!
T
@sune is ideal to answer this, but I think he's on vacation at the moment.
Hi Topher,
Thanks for the tag Mars. I am.indeed on hols in Denmark, home of the wood stove perhaps!
A direct air supply is a good idea for reducing draughts, but you have to be aware of a few things. Resistance in the duct is one, how it terminates is another, and making sure the fabric of the house is protected if you get downdraught- as the duct will then get hot.
I made a direct air guide - I can get it emailed to you if you like. I'm Sune@firepower.co.uk
The other consideration is that when you open the stove door to refuel then the duct doesn't supply that air. That air has to come from the room, and is a LOT higher flow rate than is just needed to.keep the stove burning (ie 25lt/s+). You may have enough air leaking in to supply that, you may need a direct vent to the room (nor so great for air tightness), or I came up with Airsmart which automatically opens a sealed vent to the outside whenever the stove door opens.
Hetas have a helpful assessment procedure to work this out (TN0020), which is basically shutting all doors and windows, turning on all extractors, and then testing a warm stove and chimney with the door open for smoke leakage with a smoke pellet. You could initially try yourself. If it smokes into the room a bit then open a window - does that improve things? You probably need a vent or Airsmart if so. Bear in mind that if you try to test when it's hot weather then your chimney draw will be poor, ie wait till its cold weather.
Good luck with it!
Sune
Sustainable Groups - Renewable Heating - Co-founder of Firepower. Book a one-to-one consultation to discuss your heating and sustainability here.
Posted by: @suneI am indeed on hols in Denmark,
I love the new fully Viking look... best personal avatar on the site.
Posted by: @topherHello all, first post here and a question
Worth it?
Thanks all!
T
This depends on the size of your wood burner and size/type of house. If your house is a tad leaky, stoves labelled 5kw and below don't need direct air to satisfy HETAS regs.
5kw is a bit of a moveable feast I've seen whoppas sold with that label and smaller ones.
I have a heat pump & 5 Kw wood burner with no problems (except it can get a bit hot because I have a bunch of old oak to finish up) no cold air gets drawn in at all.
- 2,149 Topics
- 47.1 K Posts
- 30 Online
- 5,667 Members
@downfield unfortunately due to a low income I only loo...
By AdamK , 27 minutes ago
... easier still is to find a scapegoat and blame all w...
By JamesPa , 2 hours ago
By GrahamF , 5 hours ago
By cathodeRay , 6 hours ago
I have heard of many people with a weakness for new car...
By JamesPa , 10 hours ago
By cathodeRay , 14 hours ago
By benson , 15 hours ago
By Judith , 16 hours ago
By TechnoGeek , 1 day ago
By Judith , 1 day ago
I’ve looked harder now (beyond OE’s site) and it’s not ...
By HCas , 3 days ago
By Old_Scientist , 4 days ago
By DavidAlgarve , 4 days ago
By SAEnergy , 5 days ago
By Temperature_Gradient , 5 days ago
By Mars , 5 days ago
