Simple water tank thermostat with legionella cycle?
@mjr Yes, I read something similar. Basically if you can find out what burner nozzle is fitted and what the pump pressure is set to and when the burner is running then the oil consumption can be pretty well estimated. Then it’s just litres/h x 10.35 to get kw/h.
Posted by: @cycleneil@mjr Yes, I read something similar. Basically if you can find out what burner nozzle is fitted and what the pump pressure is set to and when the burner is running then the oil consumption can be pretty well estimated. Then it’s just litres/h x 10.35 to get kw/h.
What is it that you are trying to measure, the overall energy consumption, or just that for producing hot water?
- 300 Online
@skd I think your guess might well be right - unfortuna...
By Toodles , 4 minutes ago
By AndrewJ , 15 minutes ago
By Bash , 2 hours ago
By benson , 2 hours ago
By trebor12345 , 3 hours ago
By RobS , 4 hours ago
By Batpred , 6 hours ago
By GC61 , 7 hours ago
By cathodeRay , 11 hours ago
By JamesPa , 22 hours ago
By Batpred , 24 hours ago
By DavidB , 1 day ago
By Slartibartfast , 1 day ago
