@jamespa "Whether anyone would be prepared to pay the rates that they would demand is of course another matter!", they are not, we have sorted a lot of installations and have never made any money on them. It is an expensive game, diagnosing and sorting cowboy jobs.
es, the house is a lot warmer and consistant ,with changing to balancing with lockshields, but using up a lot mor kw I fear . Over the last 7 days with oat ranging between -1c to 5c roughly its averaged at 77.7kw/h. (I might add thats the total House elect)
Reading back about mismatched pumping , it doesnt help when one pump, the CH, is either sucking on 22mm or pumping it to 28mm.
Glad its warmer and more particularly more consistent. Be careful about concluding its costing more though, the last few days were quite a lot colder than the previous few and any measurement over less than a few weeks is inevitably very much subject to 'noise'. That's one of the problems with this stuff, doing experiments on consumption is fraught with difficulty because we have no control of the outside conditions. With greater stability you might well find you can edge the water law/WC curve down a degree or so still and still be comfortable which will help.
That buffer tank needs to go IMHO, its just a case of when! If you want to do this then in prep you need to
trace the controls for the pumps and find out whats controlling them
write down the values of all the FSV (field setting values) starting with 2. You will have been playing with these when you were modifying the WC curve, so it will be a related menu.
of course its all your choice.
@jamespa so both feeds to the HP line pumps go to the Samsung controller and the Circulation goes to this box in pic attached All pumps are the same spec .
Other than opening up the Samsung junction, , including the two white boxes on the floor if it helps , then I assume it’s wired correctly.
The two black wires from white boxes go to Zone valves
Sounds like the HP side pumps are controlled by the HP.
@transparent I dont disagree in principle but ... in the real world where time is money and the customer doesnt want to pay the latter
existing cable runs get reused for sensor cables or bus, or whatever cable the installer happens to have in his bag gets used
switched lines use whatever is spare (personally I would at least put an indicator wrap on it when I do DiY,- I dont do it for others so cant comment on this)
cables through rubber grommets should have strain relief but if the equipment doesn't provide for it and the cable isn't going far then the inevitable happens!
I watched my heat pump installer work on his own for a week, arriving at 8am and leaving at 9pm on one night and 7pm on another, with no break at all during the day. I can forgive some things!
I think what makes this installation the more confusing is that the installer has only used three-core (lighting flex) for everything.
When he's needed three cores plus earth for the "3-way valve", he's used two separate cables. The two blues are connected to different Neutral points, one of the browns is the live supply via an on-board fuse whilst the other is a switched-live.
Both browns are outputs from the controller board.
Without any labels it's too easy to get the browns the wrong way around.
And there is a strain-relief position for the un-clamped cable, but he just didn't fit a cable tie through it. 😣
I think the Booster Heater port is for the DHW immersion heater.
There's no other terminal labelled for that, and it's the only output which we would expect to have a 20A fuse indicated on the schematic.
