help sizing rads based on room by room heat loss
Posted by: @jamespaPosted by: @adamk@jamespa thanks for the info but I think I must have something wrong. The heat loss for the whole house is about 7.5kw. The room is only 3.756m x 3.686m. Current rad is a P+ 1450mm 380mm.
Have you got the loss calculations, if so perhaps you could post?
My house loss is also about 7kW and I had one room well over 1kW, went for a Mitsubishi fancoil for that, very nice piece of kit
@jamespa heat loss list on first post.
it’s the one that says nearly 2kw, I’ve just split it into 2 rooms as we’re going to put a sliding wall between the dining and living room, plus one rad is in one area and another in the other.
Posted by: @adamk@jamespa heat loss list on first post.
The living/lounge and kitchen in your list aren't dissimilar to mine and were, for me, by far the most difficult rooms to find radiators for. I ended up with four rads in total covering a kitchen/living room and a separate long living room. The balance between two halves of each room wasn't perfect, but it hasn't mattered in practice. One of the four rads was a mitsubishi fancoil and another was the existing rad with a bunch of computer fans added (not sure how much difference that has actually made)..
I avoided type 33 as I had already fitted one in the bedroom (the other difficult room) and the wife hates it. Personally I quite like it as it looks 'serious - but I would advise to look at an example of a type 33 before settling on one, they are quite noticeably deeper.
Having got a fancoil I wish we had got a couple more. They are nice and neat, quite small, not particularly noisy and with three of them I might have been able to do some meaningful cooling in summer. Jaga Strada are also popular fan radiators and those who have them seem to rate them highly..
I was designing for 45C where the oversize factor (ie the factor by which you have to divide the DT50 output to get the output at the chosen FT) is 2.8. At 40C its 3.9 which makes quite a difference. In practice Im running at 42 so half way in between, presumably because the loss was a bit overestimated.
Posted by: @adamk@jamespa so if i have a 1988w rad at 40c @-3.1 it will only be 509w?
If its 1988W at DT 50, which is how most radiators are specified (but note not all, one brand is specified at DT70!) then yes that's right. At FT40 and RT 20 your average DT is 17.5. So your rad output is 1988*(17.5/50)^1.3 = 509W.
- 2,783 Topics
- 65.6 K Posts
- 1,371 Online
- 7,187 Members
It's the reverse, the hybrids need less space. The back...
By Temperature_Gradient , 6 minutes ago
This tool lets you input the makeup of your wall, ceili...
By bobflux , 2 hours ago
By bobflux , 12 hours ago
All the 45° elbows required for getting the primaries i...
By Singlespeed , 14 hours ago
@papahuhu Likewise, the main ‘extra’ relates to TOU tar...
By Toodles , 19 hours ago
Thanks for the reference @jamespa I can't see any te...
By bobflux , 2 days ago
By Andris , 2 days ago
By Papahuhu , 3 days ago
By Batpred , 3 days ago
By Rob of York , 3 days ago
By downfield , 4 days ago
By Mars , 5 days ago
By ian33a , 5 days ago
