@derek-m the problem with that is trying to get it assessed in a consistent way? Taking into account numbers, ages of occupants? at home all day? impact of solar gain? some people heat whole house ... others heat one room only to say 20 or 21... etc etc
i've no idea if its possible to have a way of measuring heat loss in some way to get useful info. But again i'm sure there are many issues with trying to do that so it can be measured in all weathers & times of year!
LG Therma V 16kw ASHP
Underfloor heating + Rads
8kw pv solar
3 x 8.2kw GivEnergy batteries
Manual changeover EPS
MG4 EV
I meant 70 kWh p.a. per sq.m, not £70Posted by: @mike-patrick@derek-m I like that idea as it's one number that everyone can understand. Hides a lot behind it but a useful heuristic.
Last year for mine (total energy use as ASHP not separately metered) was £70 per year per sq.m. Without others to compare I've no idea whether this is good, bad or typical. The only comparison I know of is my aged relative's house (80's built and well insulated). She uses almost 3x my annual kWh (28,000 KWh of gas and electricity). She can afford it but I've told her to use the coal-effect gas fire less and get a new thermostat for the hall as the existing one seems not to work.
Mike
For comperson I used 10000kw 5 people 230m². But it is a newbuild.
Posted by: @mike-patrickI meant 70 kWh p.a. per sq.m, not £70Posted by: @mike-patrick@derek-m I like that idea as it's one number that everyone can understand. Hides a lot behind it but a useful heuristic.
Mike
I was thinking more on a daily or even hourly basis, since that may be more effective when adjusting the weather compensation curve.
One possible way to get a feel for actual heat loss, would be to warm your home to 21C, note the outside temperature and time, then switch off your heating system and time how long it takes for the indoor temperature to fall to 20C, noting the final outside temperature.
By doing the above at several different outside temperatures it may provide the sloop of the heat loss.
It may then be possible to check the results against the calculated heat loss for your home.
@andris I used 7,000kw last year. Slightly bigger house 263m2, 4 people (2 young children).
So that's 26.6kw/m2 per annum
@batalto I see, my total of heating use is a bit of a guess as I don't have a meter. I use 10000kw total usage. Heating about 3500kw. Hot water 2500kw and 4000kw is washing drying all other electrical items.
I used about 6,500kw for power in the house. However a good chunk of that is my abusing the solar in the summer running AC, a pool heater and a hot tub. So not really representative lol
😀 that's awesome!. Hot tub sounds so good😍
I will just get a big paddling pool and fill it up for the kids for free!
Can't wait to abuse the extra power too😍
More evidence that the EPC regime is not fit for purpose
The over-prediction of energy use by EPCs in Great Britain: A comparison of EPC-modelled and metered primary energy use intensity
Abstract
This analysis compares the difference between the Energy Performance Certificate (EPC)-modelled and smart-meter measured annual energy use on a like-for-like basis in 1,374 gas-heated British households from the Smart Energy Research Lab (SERL) Observatory. EPCs and metered energy use were converted to primary energy use intensity (PEUI) to provide a comparison of the same quantity for the first time.
We show that EPCs predict significantly more energy use than metered in homes in Great Britain. EPC bands A and B show no statistically significant difference, but all other bands show a significant gap which increases as EPC rating worsens. The PEUI gap widens from −26 kWh/yr/m2 (−8%) for band C to −276 kWh/y/m2 (−48%) for bands F and G. Unlike previous research, we show that the difference persists in homes matching the EPC-model assumptions regarding occupancy, thermostat set-point and whole-home heating; suggesting that occupant behaviour is unlikely to fully explain the discrepancy.
EPCs are a core tool in the residential energy sector, and the gap between EPC-modelled and metered energy use could have a significant impact on policy, research, and industry. Future research should investigate disaggregated components of energy use, the underlying thermal model, and assumptions regarding building characteristics.
- 2,114 Topics
- 46.4 K Posts
- 82 Online
- 3,410 Members
By Mars , 15 hours ago
By Toodles , 1 day ago
By Brendon Uys , 1 day ago
By Burtis , 2 days ago
By trebor12345 , 3 days ago
By Lucia , 3 days ago
By Ashfp , 3 days ago
By Transparent , 5 days ago
By Mars , 5 days ago
By Mars , 1 week ago
By Prunus , 1 week ago
