Buying a new EV charger
I had an EV car for a few years and an EV charger for a bit longer.
You may wonder why I didn’t wait until ordering my BMW and let the salesperson “handle that for me”?
Everyone’s different. We read the regs, we wanted the wiring neat. Our wall insulation was planned. We wanted the wall tidy. So we took charge (pun mildly intended). We bought the charger unit, got a proper electrician who gave the certificate and all. When I realised the registration hadn’t been done with the DNO—well, I did it.
Now I’m eyeing up a second charger. Same house, same optimism—but definitely not the same brand.
Here’s what matters to me these days: reliability. Do what it says on the tin. No “beta features” that turns us into lab mice testers. No app that thinks my driveway is under the 5G mast. Or one that tries to deceive the ISO level API security standards my car manufacturer made available (with a sorry end).
Ideally my charger should:
- Top up the car battery to a minimum level by a set time (for those early commuters among us). No ifs nor buts.
- Do it as cheaply as possible, without any safety shortcuts.
- Use my PV power smartly or buy leccy when the grid’s cheap. And if so, charge it to a higher level.
- Have an app that remembers who it is from one week to the next. Or no app at all, what’s wrong with a touchscreen on the charger?
And yes, it should be “kind to the grid.” Though honestly—how’s a normal human supposed to know what that means? Half the time, “grid-friendly” seems to mean “we limited your charging speed without telling you.”
What about you—have you found a charger that behaves like a grown-up appliance instead of an overexcited teenager with a Wi-Fi addiction?
Which brand of charger do you have at the moment, @batpred?
We went with MyEnergi and got their Zappi. We’ve been impressed with almost everything about it, so I would happily say it’s acting like an adult. In particular:
- It integrates very well with the solar array, providing three charging modes; fast (the full 7kW for a predictable timescale), Eco (that will throttle charge up or down depending on how much our solar is producing, but maintaining at least 1.4kW since that’s the lowest charge rate it’ll handle) and Eco+ (same as Eco, but if solar drops below 1.4kW it’ll pause charging altogether)
- The app does allow for scheduling, boosting and so forth, but to be fair we never use it since…
- …there’s a very good Home Assistant integration that allows us to perform a number of sensible automations such as setting the home battery’s minimum charge level to 90% whilst the car is charging so that leccy for the car cones from either the solar PV or the grid, but not the battery.
- It’s one of the few chargers that is supplied with a physical ethernet port so you can lock down your wifi better.
- It integrates well with TOU tariffs if you want to use the app that way, although we do it through Home Assistant.
When the installer did their initial survey, they requested an isolator switch be installed. Octopus sorted that promptly and admitted MyEnergi are one of the few installers to be that fastidious. For me, wanting peace of mind that the work’s been done safely, that was a real plus point.
There are only two minor gripes I have with it. Firstly is that you can’t give it a fixed IP address; you can only give it a static lease. Secondly is that they still haven’t managed to turn off the demand side response meaning the charging may be sometimes delayed by 10 minutes unless we go into the app and hit “ignore and charge now anyway”.
As for being kind to the grid, we have another HA integration to pull the current carbon intensity of the power being generated for our region. We are able to include that in our automations as we see fit.
Thanks for sharing. 🙂
To be honest, right now I have a much better sense of what matters. I believe that I have things ready in my HA to be able to drive any dumb socket (or a wifi enabled consumer unit switch by the way..) to charge a car (readers, use a qualified electrician). But I will not be able to give it the care and attention it would need. The goal is to buy one ready to use. I appreciate the extent you go on carbon intensity, we just use price as a proxy.
Behaving like a grown-up appliance, ahem have to admit this was vague. What I mean is one that you can just do the minimum typing needed and you can rely on it. Like you plug the socket. Swipe a card or similar, off it goes. Next morning, it is ready. 😀
So I should share my experience with my leading brand charger (will omit the name as I assume they grew out of beta testing it with clients so aggressively; but it is not a chinese brand):
- Reliability: for a long time, it was not charging reliably. I call them, they ask all the obvious questions. But keep talking about their suspicion it is a GSM or 5G of whatever issue. Then they started talking about disconnecting from my BMW API, reboot, program again. This cycle repeated for what felt like over 10 times and maybe three months.
- Do what it says on the tin: when I set a price, a time for the battery to be ready and it does not tells you quicky: yes or no. It takes ages to get back to you, eventually it confirmed that it will charge to the 80% I need. It then forgot to adjust the time the battery will be ready. Little things. You close the app, go to sleep and the next morning, I would have to be lucky if my partner is not using the fossil fuel car!
- No “beta features” that turns us into lab mice testers: halfway though the problems, they alerted me that using agile tariff and/or being able to get the battery level were beta features. Since this was 6 months into what I thought was a ready product (but they must have tagged me as "guinea pig 123"). And I would need to get an electrician to send it back, they must have assumed I was essentially that little mouse inside the cage.. And they could decide to ignore reports, no matter how extensive reports they requested .. The business case was simple: no need to feed the mice, as they after themselves in the wilderness; we just decide if and when we pay attention to them. And they better not make any noise anywhere..
- It thinks my driveway is under the 5G mast: my charger is completely wireless, via 3g or whatever. A great excuse, most problems were blamed on "connectivity".
- The charger was essentially deceive the BMW/Mini API security protections: When I asked their "floating" helpdesk (home office with no ability to reach out to the product/technical team), they kept saying it is a problem with BMW, their API is rubbish. It started to stink after a few weeks. And so a new friendship with BMW was established...
I will spare you the details of when they had real struggles with handling the Octopus Agile, when the look and feel was changed: a shambolic rollout. You would think with a London base, they would know that agile development still requires testing, attention to customer communication.. But no need for it, just go double heavy on marketing. And keep the little mice in cages.
If all I had was loosing 10 minutes of charging.. 😉
Posted by: @batpredTo be honest, right now I have a much better sense of what matters. I believe that I have things ready in my HA to be able to drive any dumb socket
This is what I do, but I have a very simple economy 7 like tarrif (EON Next Drive) so the settings are trivial. EV-rated 13A wall socket, 'granny' charger, Shelley 16A relay, HA. The Shelley relay can do timing without external control, but before I got the Next Drive I had a more sophisticated automation running on HA aimed at mopping up excess solar, so I stuck with HA to automate. Currently there is no point in trying to mop up excess solar, Next Drive night time import 7p, export 15p, so its best (and simplest) just to charge (and do anything else that is possible) at night and export during the day.
Posted by: @jamespaPosted by: @batpredTo be honest, right now I have a much better sense of what matters. I believe that I have things ready in my HA to be able to drive any dumb socket
Thanks! My consumer unit collection is ready with the WiFi switch and suitably typed RCBO. It is very easy and tempting to just spend £150-200 on a safe charger that my ha could drive as a dumb socket. 😁
But part of the goal is also to help calm the ones screaming on Facebook since end of September. This is about their mini not being ready for their morning commute. Shame on the ev charger company. Perhaps the shareholders see value to have their mice.
But for the moment that fossil fuel car of ours is a good backup....it used to run out of battery . Now it has a solar panel for peace of mind! 😉
I sense the Wallbox could work Like the zappy, I believe it works on cable or WiFi. And if I am not mistaken, it could even handle agile rates... Technically, the question is whether they implement the car API connection as per iso standards CarData.
They may not allow that simple rule of two levels of charge.. But the company ethics seemed to eliminate lab features or treating paying customers as mice. Commuters have a low threshold for both of them, I believe..
Had another try with the "customer support" of my ev charger.
Just in case there was new management. Or they had been bought by someone that cares about reputation.
Bit of course no change.
Or actually now they introduced AI in their chatbot. They made sure you have to type when you cannot see where..
Lovely job. Must have saved them lots of support staff that no doubt were occasionally forcing the product development team to see the sorry result of their efforts.
Now life must be so simple without hearing About those lab mice that are nowgotyibg a brick wall.
So after one ticket, one week and a few enails , I get this helpful reply:.
Is it just me or do you also think most of what they ask is meant to be used to divert the investigation away from most their product?
"Thanks for getting in touch.
Please can you send the pictures and information outlined below?
1. Electric meter board and the surrounding cables.
2. Dedicated breaker for the charger (or isolation switch) showing the breaker switch in the up position, it should have a sticker/label to confirm it is for the EV charger.
3. Junction box.
4. Main Distribution board (where the breaker ratings are clearly visible).
5. Front view of the charger.
6. A view of the underside of the charger, showing the power cables exiting the unit.
7. Preferred Contact Number
8. Full address of charger location."
@batpred your signature says you have an Ohme Pro
what was the difference for the pro version; and don’t say more beta features for you to test lol
Ive been researching EV sockets for months now, the charger is built into the car, the very expensive box you buy is just a plug and switching circuit, bit of processing to negotiate with the car.
I’ve see a few strip downs of EV wall boxes, the component cost is less than a washing machine and they charge twice the price.
I'm looking at Simpson & Partners, who originally started Anderson, but left when that got bought out.
What EV wall box are you thinking of next?
Posted by: @majordennisbloodnokWhich brand of charger do you have at the moment, @batpred?
This is pretty much my experience of the Zappi, and I'd second the recommendation for it. I've spotted recently that Myenergi have a new charger model available now too, the Zappi GLO, which looks like it potentially has better ways to integrate with solar and, more importantly, battery storage, as the original Zappi requires a bit of configuration to stop it using battery power to charge at times.
The only additional comment I'd add is that it's a compatible charger for Octopus smart charging, which avoids the requirement for you to own one of their compatible smart charging vehicle models. The Octopus Intelligent EV tariff is fantastic for our needs, and the smart charging functionality is useful in that it provides additional 7p cheap rate time blocks if Octopus decide to charge your car outside the official cheap period.
We've had ours for 3 years now without issue (the standard warranty expired about 2 weeks ago, and we haven't purchased the extension) and if I was ever envisaging having to replace it there would need to be a very persuasive alternative option available that would make we want to move away from the myenergi platform. I'm not sure that this is the case at present.
Posted by: @agentgeorge@batpred your signature says you have an Ohme Pro
😉 Yes, the signature goes everywhere... "Home Pro", they call it, it has been failing to charge the car..
Pro in Ohme lingo probably means "more access to credit/finance".
I agree, EV chargers make too much noise from nothing.
Given the charger now does not even take the EV battery state of charge (SOC) into account, I am tempted to get a barebones box and let the HA take care of handling my import Agile tariff- so not a solution for my dad!
BMW cardata API has been stable enough to provide SOC (and amazingly free for individual use). 😀
Posted by: @batpredHad another try with the "customer support" of my ev charger.
So after one ticket, one week and a few emails , I get this helpful reply:.
This is what I answered, I really have no hope:
to your questions:
I had a registered electrician install the system a few years ago, who interfaced with you. Nothing has changed since. The EV charger is even fed from a dedicated small consumer unit. The system is also registered with my DNO and they did not ask half of these silly questions..
You surely have all the details you needed from the time of installation?
Coming back to the point of why the Ohme Home Pro was not charging at the max 8kw rate (that it usually does) even if my home provides power via an internal battery. I selected max charge, Do you have any suggestions?
This charger is meant to be able to be driven directly like a smart socket. But now that they override the "max charge" button, it does not even match the MCB (wifi enabled) that I have ready in my main consumer unit.
The thread with Ohme Support goes on, after multiple back and forth. Unbelievable..
You'll need to add another vehicle to delete the BMW. We can't do this on our end unfortunately.
Just choose the first vehicle in the list to add as a vehicle while you delete the BMW.
Let us know if any issues.
Kind regards,
Abi
I did this and still cannot remove the car from the charger config.
Additionally, Ohme led me to believe they had reengineered the way to access the car battery soc, but it looks like nothing changed!
I love to not have special treatment.
- 727 Online
By bobflux , 20 minutes ago
By Fretless6 , 2 hours ago
By Jonatan , 5 hours ago
By bobflux , 11 hours ago
By Batpred , 12 hours ago
By bobflux , 12 hours ago
By Transparent , 15 hours ago
By bobflux , 16 hours ago
By Toodles , 18 hours ago
By JamesPa , 22 hours ago
By Toodles , 4 days ago
