Why are my estimated delivered energy values so much lower than my consumed? (Mitsubishi Ecodan)
Help please,
I've never looked into my consumed v delivered energy as I don't really understand what I'm looking at. Also, as our usage doesn't appear high compared to others with ASHP whilst we seem to maintain a comfortable temperature I've just left well alone. Until today that is.
On a whim, I decided to look at the energy reports in the Melcloud app and got a huge shock. My delivered energy appears very low compared to the consumed energy values. I get that they're only estimated but still can't understand how they can be so poor.
Just wondering if I'm getting mixed up as I know so little about COP calculations or if not, where is the error coming from. I assume the delivered values are wrong as otherwise I'd expect either my house to be too cold or my energy bills much higher.
Ive tried searching online but just getting more confused with wren these figures have come from. Can anyone explain what's going on in simple terms and put my ,ind at rest please?
I've added screenshot of energy reports for 1 day and total since installation last year along with photos of the contoller screens.
I would look first at the placement of the thermistor measuring the flow temperature. I am going to assume you have an Ecodan cyclinder too, in which case the flow thermistor is held by a clip in the position I have highlighted in red (return thermistor in blue). The generated energy is a calculation of the energy difference between the flow and return temperatures at the flow rate the unit is also measuring.
The problem could be as simple as the thermistor not being clipped in and generating a lower value than than the actual temperature in the pipe. If you have a different cyclinder you'll have to have a good look to track, it might be hidden under insulation though I don;t think you would have the problem then!
The higher generated energy registered for HW could because the thermistor is picking up more heat when the pipework is radiating more heat at the higher flow temps than when you have a cooler heating flow.
210l Mitsubishi solar tank
Solar thermal
3.94kW of PV
Thanks for the advice. My set up looks a little different as it's more spread out. I've found 2 likely suspects. One of which looks like a probe and is held inside a pipe half way up the cylinder. Held in place by a bung of tissue which would probably help explain the erroneous readings. I've attached photos below. 1st is close up, 2nd is to show situ on the cylinder. Not sure about the other sensor but I've added a 3rd pic of what it might be. Bit dark but best angle I could get.
The last picture is the flow meter, the other two are of the tank thermistor in its pocket. The flow and return thermistors should be on the main pipework from the heat pump, between where it enters the house and where the pipework starts to meet pumps and junctions. I have attached an image of what the thermistors look like
. The copper body is a couple of cm long and is most likely meant to sit in a u-shaped clip soldered along the pipe. It is possible for them to sit in a bit of plumbing - a pocket - that places the thermistor more into the centre of the pipe, similar to the way the tank thermistor pushes into the tank. In either case I think the symptoms suggest at least one of these has come adrift from its proper place.
Solar thermal
3.94kW of PV
The thermistor pocket coming adrift from the flow pipe was a fault I experienced shortly after installation. It manifested itself as the measured return temperature being higher than the measured flow temperature. The sensors on my system were hidden behind the control box which has a hinge on the right hand side and can be easily moved. Photo shows sensor after moving pipe insulation.
Great thanks. I'll have another look when I get home. Couldn't see anything else near the tank but could be hidden behind lagging. I'll also take a look outside if its light enough. Least I know what to go back to the installer with.
Found them. One on the intake and one on the return. Both are held in place pretty well with cable ties and are under the insulation.
It's due for first service next month so I'll ask them to check it out.
Thanks for all your help. Least I know where they are now.
- 2,149 Topics
- 47.1 K Posts
- 38 Online
- 5,667 Members
I'm on Intelligent Go . Only since start of Feb. Before...
By Tim441 , 8 minutes ago
The following chart (from Ofgem) shows the wholesale el...
By JamesPa , 25 minutes ago
@adamk apologies if my comments appeared thoughtless an...
By downfield , 2 hours ago
By GrahamF , 18 hours ago
By cathodeRay , 19 hours ago
I have heard of many people with a weakness for new car...
By JamesPa , 23 hours ago
By cathodeRay , 1 day ago
By benson , 1 day ago
By Judith , 1 day ago
By TechnoGeek , 2 days ago
By Judith , 2 days ago
I’ve looked harder now (beyond OE’s site) and it’s not ...
By HCas , 4 days ago
By Old_Scientist , 4 days ago
By DavidAlgarve , 5 days ago
By SAEnergy , 5 days ago
By Temperature_Gradient , 6 days ago
