What happens when the outside temperature exceeds the upper WC point?
@jamespa not found the hysteresis to be a problem yet. The house warms up a lot in the sunshine so it’s only back to our desired temperature by later in the evening, if at all (high thermal mass). We toggle between ‘active’ and expanded depending on the amount of sun.
I might turn the setting of outside temperature down further (present 17C) in summer to prevent any heating on a cool night. Happily fiddling right now!
The focus of this week’s podcast recording is on “Heat Pumps & What To Do in Warmer Weather” and I’ll pull questions from the the thread so far, but if anyone has other questions on this subject, please pop them below, DM or email me (editor@renewableheatinghub.co.uk)
@bontwoody asked your question at the start of this thread to the panel. An interesting reply from Graham Hendra.
@editor Thanks Mars. Interesting talk. I will just point out however I don’t actually run my heat pump at 40C when it’s 17C outside! Don’t know why I plucked that figure from the ether 😆
@bontwoody 😂 does your unit turn off when a specific OAT is hit?
@editor not via the WC curve but as @old_scientist mentioned the setting is in the FSV menu so I was able to set that to 19C rather than it’s default of 35 C OAT
Warm weather and heat pumps.
2 months ago
5 months ago
5 months ago
LG Therma V. Software upgrades, AI (weather compensation), SCOP
1 year ago
LG Therma V R32 Monobloc. Setup advice inc flow temperature & weather compensation
2 years ago
- 2,104 Topics
- 46.3 K Posts
- 98 Online
- 3,393 Members
By EcoBaker , 2 hours ago
By Bart , 4 hours ago
@jeff And now for something I have never noticed before...
By Toodles , 5 hours ago
By Toodles , 1 day ago
By SUNandAIR , 2 days ago
By ChandyKris , 3 days ago
By rossowheels , 4 days ago
By Lucia , 5 days ago
By Scalextrix , 5 days ago
By Mars , 6 days ago
By JamesPa , 7 days ago
