Using ECODAN with Hive stat
I wasn't talking about stats in each room; just one, or maybe two if you have two zones. Lots of individual room stats can be a problem for the reasons you say. TRVs are OK as long as you don't turn too many down so that your ASHP is only heating one or two rooms. We have TRVs and most are on max but we turn the bedrooms down a little. Not off, just down.
Posted by: @brooster@kev-m that’s kind of what my installer says but I only have TRVs in each room and from other research I’ve done the advice seems to be to leave them on max and don’t create cold spots as that makes the pump work harder as the emitting area is artificially reduced leaving the pump to work harder to push out the same heat through a smaller available area? TRVs are clearly not as sophisticated as individual stats in each room. That said three rooms face due South and when/if the sun shines they can easily get to 23 with solar gain which kind of throws everything out of whack anyway…
One possible way to get reasonably constant temperature control throughout your home would be to site the thermostat, but no TRV, in the coldest room, and use TRV's in the other rooms to limit the temperature.
You may still get temperature variations, since for the thermostat to operate, there is a required temperature difference between switching on and switching off. Also I am not certain how accurate and repeatable TRV's may be.
It should still be possible to use TRV's with weather compensation control, just don't fit one to the heat emitter in the coldest room.
2 months ago
5 months ago
Ecodan 11.2kw Wireless thermostat drop outs
5 months ago
Mitsubishi Ecodan System Pressure Changes - An Issue or Expected ?
5 months ago
Transforming a Derbyshire Property into an Energy-Efficient Haven
6 months ago
- 2,149 Topics
- 47.1 K Posts
- 38 Online
- 5,667 Members
So how do you feel about surrounding these large 'villa...
By Transparent , 52 minutes ago
GivEnergy, Enphase, SolarEdge and Tesla batteries are n...
By Old_Scientist , 2 hours ago
@julianc Our solar PV has produced more this August tha...
By Toodles , 4 hours ago
I feel thats likely it, there are after all a lot of te...
By JamesPa , 7 hours ago
By Jeff , 18 hours ago
@jamespa Crossing sheep with kangaroos?
By Toodles , 21 hours ago
By GrahamF , 2 days ago
By benson , 2 days ago
By Judith , 2 days ago
By TechnoGeek , 3 days ago
By Judith , 3 days ago
By HCas , 5 days ago
By Old_Scientist , 5 days ago
By DavidAlgarve , 6 days ago
By SAEnergy , 6 days ago
