Too Many Doubts
After looking and numerous videos and reading loads of thoughts and comments on here as well as reading The Ultimate Guide to Heat Pumps it appears to me there is still too many wet fingers in the air, guess work and assumptions. We want to reduce our carbon footprint and having solar, battery and running 2 EV’s has done that but at the moment my confidence in heat pump installations is now very low. So for now I will continue to watch from a distance, I still have a heat geek installer doing a survey on Monday so will be interesting to get his thoughts.
Thanks all.
Have you considered keeping your FF boiler and supplementing it with an A2A heat pump (that can also provide cooling in summer). You could run it overnight on your cheap EV tariff to preheat the house and let the FF boiler take over at times electricity is more expensive. Whilst it may not immediately remove all your FF use, it may significantly reduce it whilst leaving the FF boiler for DHW and a bit of extra heat on the coldest winter days. A hybrid system, if you will.
Currently viewing this topic 1 user ( downfield ) and 1 guest.
Recently viewed by users: Old_Scientist 51 minutes ago, RobS 56 minutes ago, Ian S 11 minutes ago.
- 2,746 Topics
- 64.5 K Posts
- 368 Online
- 7,149 Members
Have you considered keeping your FF boiler and suppleme...
By Old_Scientist , 51 minutes ago
@toodles I invested on Miele a pair of frodge frozor wh...
By AgentGeorge , 2 hours ago
RE: Flushing system, cleaning and inhibitor
Flush and fill all complete. Octopus kindly gave us a...
For what it's worth I installed a wood burner in this o...
By BlizzardGreen , 4 hours ago
@editor Thanks for your response and recommendations. ...
By DavidB , 11 hours ago
RE: Do I add Air Con or MVHR to existing A2W ASHP?
I think I saw a diagram for an exhaust air dhw tank wit...
Thanks, however that's an answer to a subtly different ...
@toodles Such elegant symmetry. look at my lumpy bag of...
By Papahuhu , 4 days ago
RE: PV and battery long payback - sense check query
Quite probably not, but you can get a 32A relay and a S...
@ian-s Look forward to making contact soon! Regards, To...
By Toodles , 4 days ago
I don't notice mine defrosting, and most of the time Im...
By JamesPa , 5 days ago
RE: Do I need to change the control unit when replacing my Ecodan Air Source Heat Pump
Kind of you, @calumm, but it was @f1p who did the heavy...
By Majordennisbloodnok , 6 days ago
