System pressure and COP
A couple of days ago, I noticed that the pressure had dropped to nearly 1 bar. The installers had mentioned that the ideal pressure is around 1.5 bar. So, I re-pressurised to the appropriate level, and since then the COP has gone up slightly with respect to days comparable in temperature. For example, yesterday was very cold, around 2 degrees Celsius, but we still managed to reach a COP of 4 for the day, including hot water. On a similar day earlier in the month, we probably reached just around 3.5 COP. Does the system pressure matter for COP, or is this just a correlation and not causation?
16 * 435 watts PV
13 kWh Growatt battery
1 EV - Mercedes EQB
6 kW Aira Heat Pump
Posted by: @chandykrisDoes the system pressure matter for COP, or is this just a correlation and not causation?
Provided it's sufficient I can't think of any reason in physics why system pressure would affect cop
Thanks @jamespa
16 * 435 watts PV
1 EV - Mercedes EQB
6 kW Aira Heat Pump
- 460 Online
By GC61 , 52 minutes ago
By Batpred , 1 hour ago
By GoodbyeGas , 2 hours ago
By cathodeRay , 3 hours ago
By cathodeRay , 5 hours ago
By JamesPa , 15 hours ago
By Batpred , 17 hours ago
By cathodeRay , 17 hours ago
By Batpred , 18 hours ago
By DavidB , 20 hours ago
By Batpred , 21 hours ago
By JamesPa , 22 hours ago
By Batpred , 23 hours ago
