Share your electric...
Share your electricity bills
14 Users
36 Reactions
(@prunus)
Thought it would be good to start a thread about what people’s ASHPs actually consumed in electricity. Obviously lots of variables, but good to have some hard data, especially now it’s winter time.
 Here’s my whole house readings for 7 Dec 2021 to 6 Jan 2022:
D6C6718C 9CD8 4526 8C5C 3E88C41167B8
For a 13kW Grant Aerona3 in a 125m2 semi detached chalet bungalow (with a very draughty loft conversion) in Cambridgeshire. Base load of other electrical appliances probably 12-14kWh depending on use of the tumble dryer.
 The first week may be slightly too high as things weren’t set up right, but otherwise the ASHP is taking maybe 3kWh on a mild day and 25-30kWh on a freezing one.
 How do your numbers compare?
Same dates.  160m2 bungalow Lincolnshire. 14kW Mitsubishi.  21C throughout. This is just heating. Dec 25 onwards about 25% high because I wasn't using weather compensation.  10kWh mild and 40kWh cold.
71221 6122
(@majordennisbloodnok)
Same kind of time period for 105m2 bungalow in rural Surrey.
8F55AE0A 56C5 4E9D A1B1 51EA3A8886A5
I should add that the energy usage is not a like for like representation of our costs, though. Our solar panels are offsetting the demand and the battery, when not being recharged from the panels, is recharging overnight so most of the remaining demand from the ASHP is actually night time rate energy.
Previously we had an oil fired boiler and got through about 2,000 litres a year. Mid November a 1,000 litre delivery from the most competitive supplier was £605. Mid December it was £672. By my calculations if we had a year with twelve Decembers we’ll save about £400 over the oil costs, and without the solar pv we’d probably just about see parity.
We consumed 963.52 kWh of power in December (2021), importing 862.07 kWh because our solar PV generated 101.46 kWh.
So the 862.07 kWh equates to £190 on our tariff which may sound reasonable, but it's not because our heat pump is not working all the time as the HVO in the oil boiler is doing the difficult heating work.
As a comparison, and this is the scary bit, in December 2020 when the heat pump was running solo we imported 2.39 MWh of power. Back then, it cost us £262 – if we'd repeated that kind of consumption this December it would have cost us a staggering £526. It's crazy.
@editor
And that's at today's prices; next winter looks like being worse!!
@kev-m, positively terrifying.
JulianC
(@julianc)
We used 1211kWh total electric in December for a 210m2 bungalow
E35BF626 1B28 4A3D 9E08 0A8CA39D7413
This includes electric to run the house and both EVs.
This equals about £160 on my current tariff (a guess because of the day/night split)
 Luke
(@luke)
Property is a small 100sqm Victorian cottage - it is partially insulated, however windows are very draughty etc.
Groundfloor is UFH with rads upstairs, we generally keep the house around 19C and sometimes light a small wood burner to heat a lounge in the evening.
I've only got partial data at the moment as I've only recently starting monitoring heat pump use via a Shelly EM CT clamp.
Last 17 days of December - 217kWh - pro rata for month = 396kWh
First 9 days of January - 128kWh - pro rata for month = 440kWh
This is for all DHW & heating. At a guess we are using perhaps 3kWh of electricity on DHW (200l tank). Approx 93kW a month.
I haven't worked out cost as we are on E7 which is split across 4 different time periods.
Dec
Jan
This post was modified 4 years ago by Luke
(@toml1981)
@luke this is very impressive Luke! Thanks for sharing. Did you fit the room sensor yourself or get electrician in? Presume just order from NIBE?
 Luke
(@luke)
Posted by: @toml1981
The room sensor was installed with the heat pump. I'm sure your heating engineer could come back and fit it.
The sensor is recommended for radiator installs as the building responds quicker to heat input changes so I would have thought you'd benefit from it to prevent overshoot as it works with the WC curve to help adjust the required flow temperature.
(@toml1981)
@luke thanks Luke. I’ll get back to them.
separate question. Do you have your hot water/heat set on scheduled timers ?
tom
Page 1 / 3
