Samsung Gen6 and Havenwise ........
I sourced the Wi-Fi unit (City Plumbing - £122 with 15% disc for 1st App purchase) and it installed with little fuss. Havenwise App reckoned I needed a Shelly Temp unit (which they sent FOC) and that is connected after bit of faffing.
Now i am at the point of changing the Samsung settings ......... b4 I do is there a way to download/save the present settings or do I just take pics as I go ?
TIA
Samsung 12kw ASHP, nine 415w PV panel array, upgraded radiators and DHW water tank (+ pumps etc). Two wireless zone thermostat controllers and Samsung MWR-WW10N
I am no expert on this but on your gen 6 controller once you cahange user set To 0 , then havenwise takes over and I assume that the original settings stay in the back ground.
I have just changed my Gen 5 over to Havenwise over a month now and I had to change a number setting to 0 . I think as long as the controller is live the original setting stay as they are.
- 2,396 Topics
- 54.3 K Posts
- 855 Online
- 6,077 Members
Thanks for the clarification.
By JamesPa , 16 minutes ago
RE: Considering MLCP (Multi-Layer Composite Pipe) for ASHP
OK, TBH I dont know enough about MLCP to comment with a...
By JamesPa , 29 minutes ago
RE: Predicted Heat Loss from MCS calcs vs EPC vs actual
My gut feeling is that the heat pump is right sized. ...
By Tim441 , 50 minutes ago
RE: Heat pump not reaching flow temperature
Peak Energy Products most recent accounts (to June 2024...
By JamesPa , 1 hour ago
RE: Power outages and storms: A surprisingly good DNO experience
Agreed, which is no more nor less than a customer shoul...
@batpred In our case, 3 times each day when the Octopus...
By Toodles , 3 hours ago
Hi @sheriff-fatman Cycling at 5C and below is usuall...
By RobS , 3 hours ago
@batpred Here's the latest Fogstar ready built pack....
By Bash , 5 hours ago
@mike-patrick yes, even though the current system is ru...
By Tim441 , 5 hours ago
Solis confirmed that the S6 works with a single battery...
By Batpred , 5 hours ago
I am wondering if in any V2X, would the car battery eve...
By Batpred , 6 hours ago
Yes, by calculating it manually from the minute data, w...
By cathodeRay , 7 hours ago
Fan unit Making terrible noise HELP!!
One of a pair of fan units on an Earth Save Classic II ...
By GutoFfowc , 8 hours ago
OK. I think your system, which seems well designed, is...
By JamesPa , 9 hours ago
RE: Heatpunk Floor plan issues
It's usually the complete opposite... seldom that Safar...
By Mars , 23 hours ago
RE: Fan is clipping ice build up from the front of unit.
@majordennisbloodnok I’ll not go there thanks! Toodles.
By Toodles , 1 day ago
RE: Running my new Nibe ASHP efficiently
I'm new to the forum. Did you get a reply to this last ...
By Mike @ Camelot , 1 day ago
@grantmethestrength MCS requirements for DHW capacity h...
@adamk I'm observing my own system at low temperatures ...
By dr_dongle , 1 day ago
