@ecobaker Thats correct, I made the mistake of getting the same pump, but then decided to to sell it on ebay and get the UPM3 FLEX AS 25-75 130 AZA also on ebay.
@heacol easily resolved with a jumper wire on the end of the flow sensor cable 🤣
When I was commissioning my Sprsun I could not get the air out, kept tripping on a flow sensor issue. Jumpered the flow sensor out and left it at that. Haven’t seen a flow error since then 🤣 Got the air out eventually.
@heacol 👍
If the HP can't modulate below flow temp of 45 degrees and I'm aiming for flow temps of 35, is there much point in swapping out for a different pump?
Samsung Gen6 8kw ASHP in a two bed victorian mid terrace.
@ecobaker probably not
@ecobaker Probably not if the unit cant modulate at 35C. Maybe @Iancalderbank can advise if it works as low as that as i havent run mine that low yet.
I managed to talk to Glyn Hudson who was having difficulties getting PWM to work with his Samsung. However he has managed to sort it with a firmware update of the indoor controller and now it works at low flow temperatures, so it seems Samsung have sorted it.
https://community.openenergymonitor.org/t/samsung-mim-c02n-s-net-pro-dongle/25418/5
@bontwoody it will run at 35, but only stably if you have enough emitters to balance the min output of the HP. Which in my case with a 16kw gen6 unit is 3.5kw. Below about 34-35C my emitter output drops too low , so it would short cycles , so I have tuned the WC so it doesn't go much below that.
lots of run data on my heatpumpmonitor.org data, as per my sig.
@iancalderbank Thanks Ian.
@bontwoody @iancalderbank Thanks for the advice. Looks like Ill try and get a firmware update before removing the LLH, although that could be tricky.
Also I just swapped out a small radiator for a much bigger one in my kitchen which resulted in a jump of daily COP from 3.6 to 4.1, I have three other rads I want to swap as well when I can afford to do it. I think thats probably a first step before removing a LLH or changing pump.
@ecobaker mine did not need a firmware change. the PWM worked first time. I am not even sure how you would go about getting a firmware change done.
radiator changes - yes - put your effort in there first. obvious gains as you have found.
- 8 Online
By Judith , 2 hours ago
By Judith , 3 hours ago
DESNZ doing a survey which asks the right questions!
DESNZ have engaged ICF to do a survey of people who hav...
Just done your survey!
By Judith , 4 hours ago
By JamesPa , 4 hours ago
@grahamf you appear to value your recirculating loop de...
By Judith , 5 hours ago
By Tasos , 8 hours ago
By Mars , 9 hours ago
By Scalextrix , 1 day ago
Inventor (Midea) Heat Pump short cycling advice
Hello, I have a Inventor (Midea) 8kW with a 800meters Φ...
By immunity , 1 day ago
By bontwoody , 2 days ago
By Alex , 2 days ago
By GrahamF , 2 days ago
By Morgan , 2 days ago
By DREI , 3 days ago
By Profzarkov , 3 days ago
