Red Expansion Tank
@bobtskutter Hi Bob. Daft mistake with the valve.
The red expansion tank is not attached to the hot water cylinder.
I can't find the PSV you mention on the heating side.
Filling the system from 0 to 1.5 did not take long although I did slow it down towards the end. I'm only guessing maybe 5 seconds and then a few more.
The installer did ask me to check the auto air valve on top of the buffer tank to see if wet. Totally dry and always auto open so I don't know if it's been venting air. Maybe that's it!
A few weeks ago the system was drained down so maybe trapped air in the system has suddenly found it's way out. Hope that's the reason and why the pressure only dropped.
Will monitor the pressure over the weekend.
Install 13 April 2024 - 4 Bedroom Brick Detached - Heat Loss 9,281w, Design 45c at -2 - Ecodan 11.2kw R32 - 25L Buffer - 250L Telford Tempest HP DHW - All 16 radiators replaced - Auto Adapt - Mel-Pump app - Octopus Fixed Rate
@bobtskutter Hi Bob. Just a short update to say that the Red expansion tank guage is stable on 1.2 reinforcing my thought that it was air in system. It was drained down 4 weeks ago and maybe the release of trapped air was delayed or maybe I just hadn't noticed it.
I will still keep an eye on it though.
- 2,152 Topics
- 47.2 K Posts
- 31 Online
- 5,671 Members
By Old_Scientist , 13 minutes ago
@old_scientist When I applied for a G99 I asked for a 1...
By HowardP99 , 34 minutes ago
Referring to an early point, night time firing could be...
By Tasos , 56 minutes ago
It's windy down South today, which means our electricit...
By Scalextrix , 1 hour ago
I'm on Tracker at the moment and intend to remain on it...
By Scalextrix , 2 hours ago
@mars That response surely deserves a nomination for Tu...
By JamesPa , 13 hours ago
Specifying batteries, pv solar etc using ChatGPT
I thought I'd try to use ChatGPT to specify my requirem...
By Tim441 , 15 hours ago
When I interviewed Mitsubishi Electric at Installer ear...
By Mars , 19 hours ago
@lucia One look at that protection and the rodents will...
By Toodles , 20 hours ago
By Lucia , 1 day ago
What is the Heat Geek Guarantee?
We regularly hear from homeowners who are researching i...
@adamk, interesting point. I’ve not focused much on Hea...
Intelligent Octopus Flux (IOF) Review
I promised @toodles that I would provide an update and ...
@julianc Our solar PV has produced more this August tha...
By Jeff , 3 days ago
By GrahamF , 4 days ago
By cathodeRay , 4 days ago
By benson , 4 days ago
