Midea ASHP Issues with Smart Home App losing connectivity with the Wall Unit
Hi,
First Post - replaced out 16 year old gas boiler with a Midea 10KW R32 MonoBloc, already have a south facing 9.6kw Solar array and Tesla Powerwall and EV so ASHP was next logical step. Heal Loss was calculated at just under 8Kw for our 165m2 detached house. Install required 8 rads replacing. Still on steep learning curve. Install was through Puraflow. Pre Sales, and install was good, great communication. Shame I cant say the same for post installation support. Main issue we have is the Smart Home App and the wall unit keep losing connection. Sorted problem myself by the usual - reboot of the wall unit (i.e. switch off via fuse board). It then works OK for anything from 5-10 days before losing connection again. Our Wifi is good, 900MB Fibre to the premises, have them on the 2.4Ghz , no issues with any other household devices. Any one else have similar issues. Nothing from Puraflow.
Currently we have an extremely basic set-up using wall thermostat and a schedule that makes some use of our overnight 7p EV rate for water and to get slightly warmer before 05:30am . We have water set to 49C at night and 45C during the day. We mainly have 19C for the day, with a 18C between 6am and 2pm, then back to 19C. Puraflow did not give us any information of using the weather compensation. House if lovely and warm, we have a big log burner, but hardly needed to use it.
Thanks for any ideas - or point me to some reading material.
Steve
- 2,406 Topics
- 54.6 K Posts
- 230 Online
- 6,092 Members
Thanks @tim441. Interesting timing, as Passiv are a cur...
By Mars , 18 minutes ago
Sunsynk Whole House Backup Issue
Hi, looking for help and advice as my installer is usel...
By LostandConfused , 20 minutes ago
RE: Post-Traumatic Heat Pump Stress Disorder
@jamespa, I agree with you entirely. Greed, money an...
By Mars , 31 minutes ago
Hi everyone, I have a two year old Marlec Solar iBoos...
By Tallmarc , 3 hours ago
RE: Please help with the settings ecodan
Are you trying to address any particular performance is...
🤣 Well, I never managed to get the HA solis "...
By Batpred , 10 hours ago
RE: Experience - New Build / Complete New Heating System
Your sap clculations should give you a heat loss figure...
By JohnnyB , 10 hours ago
RE: Vaillant aroTherm not heating with many faults
@editor hmmm, our engineers Rae, Craig, Naz, Rob and Ry...
By ASHP-BOBBA , 11 hours ago
Indeed! And my apologies, I should have expected you...
By Batpred , 11 hours ago
RE: I’m glad the cold spell is over!
@editor as a reply for this date the 6th of Jan in o...
By Nursethescreens , 12 hours ago
RE: Heat loss based on gas usage
@jamespa Thanks. The numbers posted above were jus...
By Bash , 13 hours ago
RE: Heat pump not reaching flow temperature
I would describe this as either a fault or a configurat...
By JamesPa , 13 hours ago
RE: New Daikin 11kW Altherma 3M install - is it working as it should?
I forgot to mention: Octopus measured our heat loss at ...
By Toodles , 16 hours ago
RE: Considering MLCP (Multi-Layer Composite Pipe) for ASHP
Thanks Mars and thank you for reaching out to so many p...
By iotum , 17 hours ago
Forum Handle: @davec Manufacturer: Peak Energy Mode...
By DaveC , 17 hours ago
Well, the guy came out, turned the heat pump to max, we...
By razz , 17 hours ago
Midea R32 setup and bizarre running with lengthy off periods?
Hi I am new to the world of ASHP and have just had a re...
By Countryman Helmsley , 17 hours ago
Given the weather has been relatively stable, the empir...
By Batpred , 18 hours ago
RE: GSHP WOES! Midland based engineer recommendations?
@editor That is very kind! Thank you so much.
By johnbroome , 19 hours ago
@wally Hi I am not sure how large your house is b...
By TechnoGeek , 20 hours ago
