Installer Fitted 9kW Instead of 11kW Heat Pump and Changed MCS Paperwork - What do I do?
@editor I have now been allocated a complaint handler by NAPIT. The email advising me of this states 'In accordance with our formal complaint's procedure, we have now referred this matter to our technical team for an initial review. This is to determine whether any technical issues are present that may have contributed to the concerns raised.
@jamespa thank you again. I know using the offset to try to raise the room temperature isn't ideal, but I was desperate! It was one of those times when the LWT wasn't reaching near what it should according to the WD curve. However I have adjusted the curve very slightly to 50 at -2 instead of -3. I've had a look at the installer's manual which I was given a copy of. It's as badly written as the user's manual. But interestingly there is a table showing 'space heating setpoint range' which is maximum 55 for underfloor heating and maximum 60 for radiators - which I have. My system is set to 50 maximum but I've had a look at the installer settings and can see how to increase that to a maximum of 60. Is that worth trying? I have always been puzzled as to what happens when as you mention it reaches the low temperature at which the curve flatlines and can't respond any further to falling temperatures. I'm thinking on the very cold days it may well have been -5/-6 or lower overnight and the house has dropped in temperature and the ASHP is just scrabbling all day trying to reverse that? No doubt it won't be good for my SCOP but my priority is being comfortable over cost.
As far as I can see there is no way to push the system to use purely the immersion heater for DHW, and I'm afraid my skills wouldn't stretch to the kind of modification that you have made. I would likely have to speak to the service company about that.
I wonder about initially changing the setpoint to 55 or 60 and seeing how I get on in the next cold snap. I would greatly appreciate your thoughts on that. Many thanks.
Currently viewing this topic 3 users ( Sheriff Fatman, Mars, MairiA ) and 9 guests.
Recently viewed by users: Transparent 48 seconds ago.
- 2,418 Topics
- 54.8 K Posts
- 366 Online
- 6,098 Members
RE: Ecodan Pump Issues… Circulation pump turns off when heat pump compressor turns off
Can you tell me if you have an FTC6 or FTC7 If you h...
By ASHP-BOBBA , 1 minute ago
RE: Ideal HP290 14kW ASHP - how to optimise
Roughly this should cost you £250-£300 per peak month a...
By ASHP-BOBBA , 52 minutes ago
RE: Installer Fitted 9kW Instead of 11kW Heat Pump and Changed MCS Paperwork - What do I do?
@jamespa thank you again. I know using the offset to tr...
By MairiA , 2 hours ago
Here's that section of the Installation Manual: &nb...
By Transparent , 4 hours ago
RE: New Daikin 11kW Altherma 3M install - is it working as it should?
@toodles Thank you for your input. As the days have got...
By Synthbuilder , 4 hours ago
Frost Protect/Freeze Stat is an operation mode, where D...
By F1p , 5 hours ago
RE: Fan unit Making terrible noise HELP!!
@gutoffowc Oh no, sorry to hear that, are you in the Ke...
By ASHP-BOBBA , 6 hours ago
RE: Sunsynk Whole House Backup Issue
@sheriff-fatman - could you please re-post that in the ...
By Transparent , 7 hours ago
RE: Running my new Nibe ASHP efficiently
I didn't. I spent a while manually messing around with ...
By jamieheatpumpnew , 9 hours ago
RE: I’m glad the cold spell is over!
I comparison with the 65kWh used above yesterday was on...
By Judith , 9 hours ago
I should think so, I thought that pretty much universal...
By JamesPa , 10 hours ago
I'm also inclined to look into how a defrost is actuall...
By cathodeRay , 10 hours ago
MLCP (Multi-Layer Composite Pipe) for ASHP
@editor nope. The info you reported was sufficient for ...
By iotum , 20 hours ago
RE: Experience - New Build / Complete New Heating System
@vincro I would be surprised if it is much above 5 to 6...
By ASHP-BOBBA , 21 hours ago
RE: Post-Traumatic Heat Pump Stress Disorder
Yes bang on and maybe I can illustrate that by way of e...
By iotum , 24 hours ago
RE: Replacing my 18 month old Hitachi Yutaki ASHP
A big thank you to @jamespa for all his efforts online ...
By trebor12345 , 1 day ago
RE: GSHP WOES! Midland based engineer recommendations?
@editor It is indeed for servicing. My current service ...
By Morgan , 1 day ago
