found the code! 17. what do I look for? and what readings are best?
Hi Nigel42,
For me to be able to provide the best help and advice, could you please provide a list of the equipment installed within your system, so that I can ensure that we are both looking at the same information.
@nigel42 you're wasted on this forum. I hear GCHQ is always looking for code breakers
Posted by: @witchcraft@nigel42 (Now if you can work out how to change the DHW temperature please tell me 🙂 (I have a Vaillant Arotherm Plus 12kW)
For my Arotherm Plus 12kw which is currently set for Fixed heating mode, I can change the DHW temperature on the Sensocomfort by going to Control -> Domestic Hot Water -> DHW Temperature
I've still to test in other modes but according to the manual you can try here:-
Settings -> Installer Level -> Installation Configuration -> DHW Temperature
C.
@derek-m hi, Here's my set up in photos.
Other factors which might help you.
3 bedroom semi detached 130m2
recent refurbished house, lots of insulation!
No Gas
UFH to ground floor, no rads.
Electric rads in bedrooms . Electric UFH in 2 shower rooms.
4.62kw solar panels
Posted by: @nigel42@derek-m hi, Here's my set up in photos.
No Gas
4.62kw solar panels
Hi Nigel,
I think Colin has kindly provided details of how to adjust the DHW settings in an earlier post.
I was surprised to read that you have electric radiators in the bedrooms and electric UFH in the shower rooms, seems strange if you have an ASHP.
@derek-m hi, we went for Electric rads because we don't like too hotter bedrooms and just turn them on and off was as when needed. What would you have fitted? Curious to know!
What temp would you recommend for the DHW?
thanks again.
Hi Nigel,
From the energy consumption and hence running cost point of view, even in Winter an ASHP would be approximately 3 times more efficient than direct electrical heating. If you are not using the electrical heaters very often then they should not be too expensive to run.
DHW in the 45C to 50C range should be adequate. It very much depends on your personal preference, the size of your tank, and how much hot water you use. About once per week your system should carry out a Legionella Cycle, heating the hot water to 60C -65C for at least 10 minutes.
@derek-m hi, our tank is 300L and there is only 2 of us, only showers and the UFH are the main users of the water. I've just reduced the DHW from 50 to 48!
Is there something else I should be looking at?
Thanks
Hi Nigel,
I am trying to get my head around how your system is actually being controlled, since according to your photo's, you appear to have the main Vaillant controller, plus what I think is the Vaillant remote controller, also at least 2 Heatmiser thermostats and a Heatmiser unit that may be for the UFH.
Did the installer give you any instruction as to what all the different controls are doing, and how they may interact with one another?
Would it be possible for you to list where each of the above devices are located, and they appear to be controlling.
Have Consumers Been Lied to About the Efficiency of Heat Pumps Made in China?
2 weeks ago
1 month ago
4 months ago
4 months ago
7 months ago
- 2,131 Topics
- 35 Online
- 5,656 Members
Firstly thank you for posting and please be assured no ...
By JamesPa , 2 hours ago
Having moved from Agile in early Feb to Intelligent Go ...
By Tim441 , 2 hours ago
By Tim441 , 3 hours ago
By brad , 22 hours ago
By Tim441 , 2 days ago
By Abernyte , 2 days ago
By Eliuccio , 4 days ago
By Scalextrix , 4 days ago
By Mars , 5 days ago
By JamesPa , 5 days ago
By Scalextrix , 5 days ago
By Toodles , 6 days ago
By Judith , 1 week ago
