Faulty Clivet heat pump out of the box
@steveimpey excellent to hear that you're up and running finally. 👍😀
Planning your dream house? Book a simple one-to-one consultation to get you on a good path - here.
@steveimpey Welcome to the Homely control club! Toodles.
@steveimpey glad you got it sorted and agreed- being ignored by Clivet tech support is massively frustrating as I'd expect them to be liaising directly with an end user as well in this scenario, rather than just going through installer. I know their tech support are about as they replied to me about a minor query I had a week or so ago (replied on a Sunday in fairness). Sounds like they've developed new controls rather than recommissioning/rebranding the midea control panel as they had been doing, with evidently some teething problems.
Regarding homely, we had been using this and found it to be a reasonable solution but have since removed and just using manufacturers controls. Therefore I would make sure they sort the native controls issue as well asap and stay on the case with that, so that you have that option as well going forward should you wish to change it for whatever reason (granted many people are happy with homely- just didn't suit us).
- 2,364 Topics
- 53.6 K Posts
- 178 Online
- 6,029 Members
RE: ASHP sizing - value of Heat Transfer Coefficient
Sorry, but I cant see what the point of this is unless ...
By JamesPa , 6 hours ago
TC Thermostatic Radiator Valve TRV Plastic Decorators S...
By Toodles , 10 hours ago
RE: Ecodan unable to hit legionella target temp - what's the consensus?
UPDATE: Thanks everyone who commened with suggestions h...
By 9jwr9 , 14 hours ago
How long will your energy contract last?
Some heat pump tariffs don’t run as long as a heat pu...
@morgan They are unsupervised these days, can’t get the...
Exactly. We only need to compare conditions, to decide ...
By cathodeRay , 4 days ago
I found because I have very low heat loss I can set bac...
By RadWhisperer , 4 days ago
RE: Need Help Optimising My Rushed ECO4 Install: 12kW Bosch Heat Pump
Welcome @mickamills We too have an oversized 12kW Sa...
By Old_Scientist , 4 days ago
RE: My Powerwall 3 Consumes 3-4 kWh/Day in Self-Consumption: Is This Normal?
@caron I can confirm that the power usage of the PW3 is...
RE: Speedcomfort radiator fans
Thats true, but having tried (and succeeded) in constru...
@bash brilliant, thanks for the feedback
By energy9165 , 4 days ago
RE: Heat Pump Heats the House… But It’s Not Cosy. Emitter Changes or System Tweak?
@alastair There I was, feeling grumpy, he said “Cheer u...
By Toodles , 4 days ago
RE: Grant Aerona: Is there a setting to keep the 2-port valve open during pump blockade
Depends on OAT. Mine cycles at OAT>10 and of course...
@transparent My conclusion is as you have noted, tha...
By Bash , 4 days ago
RE: Mitsubishi Ecodan R290 10kW performance
And to you too. Wishing you a very enjoyable festive s...
By Sheriff Fatman , 5 days ago
RE: External pipework insulation
They do? But that isn't apparent from the photos we'r...
By Transparent , 5 days ago
@velcro welcome to the forums. Please feel free start a...
By Mars , 5 days ago
Daikin EDLA11D3V3 DHW Settings
I have a newly installed EDLA11D3V3 which I'm still get...
By Velcro , 5 days ago
