Ecodan 11.2kw Wireless thermostat drop outs
Hi,
I have some interesting behaviour with my wireless thermostat (the one that comes supplied with the FTC7 controller). It looks like it drops out for a bit that causes the heat pump to stop for a few minutes and then start back up again(graphs attached). I was wondering if anyone else had similar experiences? I have moved it to be closer to the control unit, with no luck. I do have a lot of zigbee devices... not sure if that is relevant. Im using https://github.com/F1p/Home-Assistant-Mitsubishi-Ecodan-CN105-to-MQTT to get log all the data from the Ecodan FTC7 controller
Craig
I've had our FTC7 wireless thermostat lose connection to the controller a few times, does yours display 3 in the top right where the temperature usually is? It didn't stop the heat pump when it did this though. I've moved it from beside the mesh WiFi router (interference seemed the likely cause) and it's worked fine since.
New Mitsubishi Ecodan 11.2kW installation - L9 errors and maybe more
12 hours ago
Ecodan with FTC7 - True Weather Compensation
3 days ago
Ecodan unable to hit legionella target temp - what's the consensus?
2 weeks ago
Mitsubishi Ecodan 11kw Defrosting Issue.
4 weeks ago
6 months ago
- 2,396 Topics
- 54.3 K Posts
- 235 Online
- 6,077 Members
No need to create a new thread, @sheriff-fatman. You do...
By Majordennisbloodnok , 5 hours ago
RE: Power outages and storms: A surprisingly good DNO experience
Well done to Scottish Power for doing a good job. Well ...
Fair point. The highest frequency of defrosts I'd seen...
RE: Heatpunk Floor plan issues
It's usually the complete opposite... seldom that Safar...
By Mars , 6 hours ago
@mike-patrick interesting update - thanks.I've been thr...
By Tim441 , 7 hours ago
I remember reading in some inverters. They mandate a se...
By Batpred , 8 hours ago
RE: Fan is clipping ice build up from the front of unit.
@majordennisbloodnok I’ll not go there thanks! Toodles.
By Toodles , 9 hours ago
@majordennisbloodnok Back in the 80’ or 90’ we had a te...
RE: Running my new Nibe ASHP efficiently
I'm new to the forum. Did you get a reply to this last ...
By Mike @ Camelot , 11 hours ago
@grantmethestrength MCS requirements for DHW capacity h...
By Toodles , 11 hours ago
Great to hear! I just figured this out a day or tw...
By anotherdaveuk , 12 hours ago
@adamk I'm observing my own system at low temperatures ...
By dr_dongle , 17 hours ago
RE: Free Ecoheat Heat Pump Install
@deltona Yes older houses are problematic like that, bu...
By bontwoody , 2 days ago
As I mentioned early on the cost of supplying and fitti...
Great point, one of the key ones in my chat with Octopu...
Let me point out that there are many Chinese suppliers ...
@majordennisbloodnok — The Two Ronnies Mastermind sketc...
Just realised that this image of the cylinder cupboard ...
Two thoughts: 1: Let's ask @david-s if Primary Pro in...
In the diagram below, I describe my understanding of th...
By Batpred , 3 days ago
