Daikin Altherma ASHP help needed – Radiators are not heating up
Forgive me if this is in the wrong section but this is my first post.
My Daikin Alterma seems to be working but I don't have much heat coming through the radiators.
Please can someone tell me if the figures in the attached photo are correct and if not tell me how I can fix this?
Many thanks in advance 🙂
s
@uffda welcome to the forums. Is this something that has started recently and the rads were fine up until now?
That’s a daikin hybrid system which uses an intergas boiler as the gas fired bit.
looks like it’s firing at 31 degrees flow temp, which is probably about right depending on your radiator sizing and the outside temp when you took that photo.
I prefer to spend a bit more on running costs and have my weather comp bottom out at 38.5 degree flow, as you can at least feel that temp flowing through the rads.
@uffda I’ve just received a message from Daikin who have kindly offered to send out an engineer to you to see if they can resolve the issue. Please let me know if this is of interest.
Hi @uffda. Would you like me to put you in touch with Daikin and their engineer to help sort this out?
Posted by: @uffdaForgive me if this is in the wrong section but this is my first post.
s
Are you maintaining the desired indoor temperature?
During milder weather the heat loss from your home will be much lower, so your radiators do not need to be very warm.
- 2,475 Topics
- 56.9 K Posts
- 252 Online
- 6,165 Members
By errmm , 5 hours ago
By JamesPa , 6 hours ago
By JamesPa , 7 hours ago
By DavidB , 8 hours ago
By CraigH , 8 hours ago
By Rusty , 8 hours ago
By Mars , 8 hours ago
By AndrewJ , 10 hours ago
By Batpred , 11 hours ago
By Toodles , 12 hours ago
By Papahuhu , 12 hours ago
By Batpred , 13 hours ago
By Gruff2001 , 14 hours ago
By Steelbadger , 1 day ago
By Jancold , 1 day ago
By L2jad , 1 day ago
