Compressor attempts...
Compressor attempts start but fails - Nibe Fighter 2005 8kW
5 Users
9 Reactions
@ian21stcent
I assume you have checked filters which is a common reason for a range of failure symptoms?
(@skyefarmer)
@ian21stcent Hello. I replaced the soft start on mine about 3 years ago. The only indication I had that the soft start had failed was the fault led. I couldn't find an exact replacement, the new unit had better spec. but was a bit taller which caused slight problem. I'm not on Skye right now so can't tell you what replacement was. I will check email. But I think you have same issue.
(@skyefarmer)
@ian21stcent Email archive is invaluable. I purchased a CSS-25U Emerson Compressor Soft Starter 25A from Kempston Controls
Page 2 / 2
