@clairelp well that's a full house for me, after everyone here mentioned pipework clipping , fan noise, pumps, auto air vents. Need to listen to experts that install this stuff every day. Glad it's sorted for now.
Nope no luck.we tried setting back again and the defrost cycles came on woke us up. It even was vibrating our bed. I had noticed it doing this before and my husband I didn’t think he believed me till last night.
i will call them back again, as it’s definitely not normal to be vibrating furniture.
I might see if they can turn the buffer off, as this is what is causing the loud unusable noise not the ashp. During the night when it’s doing its anti pipe freeze cycle it uses the vessel and that’s when it’s vibrates the furniture.
To add insult to we also have a pipe come though our ceiling. They said it’s where during install they had leak made ceiling wet and the must have pushed it through. So we now currently have a hole on ceiling playroom. 😩
I also did ask about the anti vibration clips and they said they don’t use them.
@clairelp I did think the solution sounded hopeful, and am disappointed to hear it didn't work. Please keep us updated.
Free UK shipping.
📘 From Zero to Heat Pump Hero
🛠️ Bodge Buster
New to heat pumps?
@editor Yes indeed! A great shame as it sounded so hopeful; so I take it the system will be being turned off at night for a few more days. 😒 Hope your installers return soon and find the culprit. Regards, Toodles.
The pipe on that bar looks the prime suspect for a noise issue, should be able to lift slightly to get some insulation in-between pipe and metal bar.
The other part is the auto air vent, just undo the little black (assuming it's closed)
Not sure if this is something @louise-howlett can potentially assist with?
Free UK shipping.
🛠️ Bodge Buster
New to heat pumps?
@editor Thanks for the enquiry I'll get my technical buddies to take a look at the photos on this thread. There can be several causes of noise and vibration. We do cover the Bury St Edmunds area.
Commercial Director: R A Brown Heating Services
- 2,756 Topics
- 64.9 K Posts
- 2,326 Online
- 7,161 Members
Quite probably, does the guarantee come with any defini...
By JamesPa , 6 hours ago
Good but - with your recirculating pump a high proporti...
By JamesPa , 8 hours ago
No worries, I can't really argue with your logic and I ...
By Old_Scientist , 11 hours ago
RE: 7kW EV Charger Options Advice
Thank you Rusty, all of those subtleties were lost on m...
By Judith , 16 hours ago
Flow rate is set by pressure created by the circulator ...
By bobflux , 1 day ago
RE: Glass lined Cylinder for private water supply
I have one of those... a Thermal Store. In my case th...
@tim441 Here are those same three month periods for 202...
RE: Adding additional Solar Panels to a DC coupled battery system
@transparent thank you for your reply above. As alway...
RE: How Accurate Is My DIY Heat Loss Calculation?
@kilgorexv definitely a larger inverter will help and m...
By AndrewJ , 4 days ago
@rob-of-york — thanks for posting this, all very useful...
By cathodeRay , 5 days ago
The installation is almost done! I've written up two ...
By tomasmcguinness , 5 days ago
RE: Switch suitable to change between two inverter CT's
Last winter my battery ,32KWh, could run the house com...
By Jancold , 5 days ago
RE: HeatGeek vs Octopus surveys: puzzling disparity - any ideas why?
Agree with Major. And even if I was very happy with ...
By Batpred , 5 days ago
RE: Is the "divide by 2900" rule still valid?
There is another estimator that you could use, a formul...
By Rob of York , 5 days ago
