Daikin Altherma noi...
[Solved] Daikin Altherma noisy heat pump - help and advice needed
9 Users
30 Reactions
12.2 K Views
(@clairelp)
CABF220E 9E36 4B6B AAD5 D9599C47EABA
022A000D 0C3F 4949 AEAA EC993E0AE5C4
479FD1CF 5586 45E1 A3B2 81EBC004C8BF
34E81471 6D9A 4FA1 8AB0 88D648B9B9EF
9FA0C204 010E 45E2 9E7D A3279DCEA9E0
B61ED66E D553 482A 9EE4 383D19027EA0
098BB5A5 A9B7 4C40 B60C 7C2C618658A9
9534A4C5 2055 4998 9AC8 9C9703E27303
686FEB7C 105D 42C9 BBC9 31A3E3AAB906
65A9DE58 FDD0 43A0 8A4A 252C63B1F57F
503651F1 1F5D 4CE1 85D8 D8A374D48C70
8CF22B0C FC27 4018 A2B2 409BB0F460B4
Sorry don’t think pictures attached
(@clairelp)
9D80E866 9C59 433D A327 9CA2629575D2
Under this is my bedroom wall, I think the noise is from here somewhere. Do these vessels make noise?
(@kenbone)
@clairelp finally I can see that you have a volumiser, not buffer setup. So there should be not extra pumps on the system. The pump built into the Daikin is quite strong, I can't see a bypass (but it's hard to tell with the quality of pictures)
This is what they look like, it maybe in the airing cupboard, do you TRVs on every radiator.
Does the noise stop when doing hot water.???
Screenshot 20240227 132438
(@kenbone)
@clairelp only if they don't have enough water in them, system what's the pressure gauge reading.
(@kenbone)
@clairelp there should be an air release valve behind
Screenshot 20240227 135856
Sune
 Sune
(@sune)
Trusted Member Contributor
@clairelp I'd expect the primary pipes - which is the ones that connect your heat pump to to the volumiser, to that black and red Esbe valve, and to any manifolds or branching off in your cupboard, to be at least 28mm diameter. From the pictures it looks like they >may< be 22mm? It's hard to tell though.
Apologies - I've forgotten the output of your heat pump..... There's a limit to how many kWhs you can get down each diameter pipe to not go over 0.9 - 1m/s velocity. For 22mm the limit is around 6kW. For 28mm it's more like 10kWh. * Could you please check what the diameter of the pipes going to your volumiser are please? The volumiser is the small gray tank thing in the attic.
Did you then say that each pipe heading off around the house is 10mm? You can get around 1kW down each one of these to not go over 0.9 - 1m/s velocity.
The reason you would want to keep to that velocity limit is it tends to get noisy above it. Also much above 1.5 and it starts to erode the internal of a copper pipe.
As Ken and others thought previously the pipe clips attach the pipe directly to the wood in your attic. An alternative would be to use a clip that goes to the outside of the insulation material. There is a brand called "Primary Pro" that is a favourite with heat pump installers. As you have a cold attic I'd advise consider this a cold space and upgrading the insulation up there - you'll save money in the long run.
Ken's suggestion to check the air vent is a good one too.
*These numbers assume you have glycol in your system, and that the dT of your heat pump is 5. dT means the delta T - it stands for the temperature difference between the hot pipe from the heat pump and the cold one. Delta means "difference" in Latin. As dT increases you can get more and more heat down a pipe within that velocity limit.
Sustainable Groups - Renewable Heating - Co-founder of Firepower. Book a one-to-one consultation to discuss your heating and sustainability here.
(@clairelp)
7B0BAEB7 CFB0 45A5 81AB 4BB07DCE5329
D9D044EF C3D2 4EDE 9CC8 E33D1648BF71
F5ABFDE6 569C 4E3F AA4C 9A57ED2274F9
F1832C12 D115 4A9A A143 082BB3A92765
08DD2C19 5E54 4B2B BFCD 3089CE3FBC3D
F861D074 5385 4BFF B849 B5F2180B1A8E
46473EAA 8EEF 4AFB A828 809584C4E4B5
57FD1DD9 BB50 463B 9191 9CA4EE73105E
Thank you for looking at pictures for me. I cannot see one, but will get husband to look.
the two heated plumbed towel rails are the only radiators without a trv
no still noisy with water heating in fact probably worse. It’s at its noisiest probably when doing water and that frost cycle.
(@kenbone)
@clairelp here is the bypass valve
Screenshot 20240227 150934~2
(@kenbone)
This is the filling loop and gauge.
Screenshot 20240227 150934~3
(@kenbone)
@clairelp
What's been happening ?
(@clairelp)
@kenbone
Hi, we not had chance to get in the loft to look at the valve yet, difficult to go up in loft making noise when children asleep in the evening.
I did look at pressure gauge in cupboard and it about 1.6.
Friday installers are coming so I will keep you posted. We also have installers msc compliance department checking the install following week. Hoping they will have an answer 🤞🙏
the ashp does have anti freeze valves, with it not been below freezing hoping be okay to keep turning off for a couple of nights.
also looking into sound proofing and insulation for the loft.
(@clairelp)
Hi,
Installers, have turned down the velocity to I think he said 21-22 and was previously 24. Think he said in the bypass valve. And I sorry can’t remember exactly but I think he said like it around 21 and maybe 24 was making too much noise.
At moment, I don’t think I could hear it and running quieter, it’s only just done so I will test it later when doing hot water and have to wait for a cold night.
They also did some settings on the frost cycle. They said it shouldn’t be coming on when not cold enough and shouldn’t be constantly going. Said there is two defrost settings one I think he said for the pipes and one for actual pump. They said if changes didn’t help they will contact Daikain, as some setting they can’t change.
Page 3 / 6
