Hello! I today received my first quote from an installer who actually came to the house (two others so far were preliminary online-only guess-quotes). I was a little surprised to see one thing in the contract: it states that I have the pay the £7500 extra if the BUS grant does not go through.
Is that a typical way that installers deal with the BUS grant in contracts?
My first thought was: they are MCS certified, so they know what is required to be done with the actual install and the paperwork ... I have no ability myself to influence if the BUS grant succeeds, so why am I on the hook for the cost (lack of rebate) if Ofgem does not pay out?
I searched on this forum and found @grahamh Graham's post about BUS ( https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/the-new-heat-pump-grant-bus ) and he did mention something that made me have a second thought -- to quote him:
They will quote and then register the quote with the BUS website. Ofgem who run the BUS scheme will contact the homeowner to check they have been quoted and are happy, if they are the installer will be told to proceed and a voucher will be put aside for the job. Once the job is installed the installer will invoice the homeowner the cost of the heat pump minus £5000. The homeowner will be asked to confirm to Ofgem that they are happy. When they confirm they are the voucher will be issued to the installer, they will or should receive the £5000 within a week from Ofgem.
(He wrote this before it went up to £7500)
Is the installer just trying to cover himself if I do NOT confirm to Ofgem that "I'm Happy" with the installation? That part I guess I do control.
Sounds to me like a bit of rear-end covering tactics; should things go pear shaped for any reason, you are on the hook for the ‘Bus Ticket’ element. This may be a component in their standard contract terms, but if so, it suggests that they may not have sufficient confidence in their own workmanship! Are you otherwise happy with the installer? What is your gut feeling telling you? Regards, Toodles.
Posted by: @sussex-greenishHello! I today received my first quote from an installer who actually came to the house (two others so far were preliminary online-only guess-quotes). I was a little surprised to see one thing in the contract: it states that I have the pay the £7500 extra if the BUS grant does not go through.
Mine did that also, I wouldn't be surprised if its common/written into the MCS contract template.
You get about 3 emails from the BUS people either asking you to confirm the installer or confirming that the grant has been provisionally authorised, so in practice there is a reasonable degree of reassurance. In particular there is a point in the process (before the installation) where the installer has made the application for the grant and you have to confirm that you authorise the installer to access the grant on your behalf. Until this point I wouldn't regard it as secure, so no way would I let an installer go ahead until this point was reached.
11 hours ago
2 days ago
3 days ago
Where has Watson gone?
3 days ago
First time wall mounting an ASHP
2 months ago
- 2,396 Topics
- 54.3 K Posts
- 223 Online
- 6,077 Members
No need to create a new thread, @sheriff-fatman. You do...
By Majordennisbloodnok , 5 hours ago
RE: Power outages and storms: A surprisingly good DNO experience
Well done to Scottish Power for doing a good job. Well ...
Fair point. The highest frequency of defrosts I'd seen...
RE: Heatpunk Floor plan issues
It's usually the complete opposite... seldom that Safar...
By Mars , 6 hours ago
@mike-patrick interesting update - thanks.I've been thr...
By Tim441 , 8 hours ago
I remember reading in some inverters. They mandate a se...
By Batpred , 8 hours ago
RE: Fan is clipping ice build up from the front of unit.
@majordennisbloodnok I’ll not go there thanks! Toodles.
By Toodles , 9 hours ago
@majordennisbloodnok Back in the 80’ or 90’ we had a te...
RE: Running my new Nibe ASHP efficiently
I'm new to the forum. Did you get a reply to this last ...
By Mike @ Camelot , 11 hours ago
@grantmethestrength MCS requirements for DHW capacity h...
By Toodles , 11 hours ago
Great to hear! I just figured this out a day or tw...
By anotherdaveuk , 13 hours ago
@adamk I'm observing my own system at low temperatures ...
By dr_dongle , 18 hours ago
RE: Free Ecoheat Heat Pump Install
@deltona Yes older houses are problematic like that, bu...
By bontwoody , 2 days ago
As I mentioned early on the cost of supplying and fitti...
Great point, one of the key ones in my chat with Octopu...
Let me point out that there are many Chinese suppliers ...
@majordennisbloodnok — The Two Ronnies Mastermind sketc...
Just realised that this image of the cylinder cupboard ...
Two thoughts: 1: Let's ask @david-s if Primary Pro in...
In the diagram below, I describe my understanding of th...
By Batpred , 3 days ago
