Air Source Heat Pump - Side Alley Suitability
@jamespa I used an assumed indoor temperature of 18C. Is this what you mean by nominal heating temperature? If i reduce the indoor temperature to 15.5C for the calculation, then the estimated peak heat loss drops to 6.7kW
Posted by: @ad3628@jamespa I used an assumed indoor temperature of 18C. Is this what you mean by nominal heating temperature?
Thats probably fair enough. The degree-days calculation (on which quite a few heating formula are based) uses the formula
sum (max (Tbase-OAT ,0))
where Tbase is usually set at 15.5 (not sure why this figure is chosen). This basically ignores completely any time periods where the OAT is above Tbase. In the height of the season, when the OAT never rises above Tbase, thats the same as Tbase - average (OAT), so degree days (which are easily downloaded for a load of whether stations) can be used as a proxy for OAT - which is what I did in my graph.
Another way to look at is that your house benefits from waste heat from your electrical appliances. Given that the average house uses about 3.5MWh/year, and you can reasonably assume all of that ends up as heat, this is 3500kWh/365/24 = 400W. You can add 100W per person to that, so 600-800W in total which is not insignificant.
Personally I preferred simply to plot gas consumption vs average OAT (for the reason set out above you can alternatively use degree days instead of average OAT). This then automatically takes into account heat sources other than the heating system, and allows you directly to read off the figure at any desired design OAT. If your water is heated by gas this also includes your water heating, so no need to add that in (that's probably true in your calculation also).
In principle you need, in this calculation, to account for the efficiency of the gas boiler which could be as high as 110%* if its actually condensing, or perhaps as low as 75% if its very old. Very few boilers are set up to condense because installers set the flow temperature too high and we, stupidly, don't generally use weather compensation for boilers in the UK, so the return temperature is above the condense temperature. This means that even modern boilers are most likely operating at max 95% efficiency, so measured gas consumption, provided most of the house is warm most of the day and night, really could be considered an upper limit on your house heating demand.
from what you have said I think there is a fighting chance 8kW will suffice, particularly if you accept that a little supplemental heating may be needed if there is an extended very cold patch. Obviously its your call and also depends on whether you can persuade an installer to take any notice of measured consumption (some will, others wont)
Going back to the low loss header matter and noting that this fixed your neighbours system, please note that its actually the secondary pump that does the job, because it provides enough oomph to push the water through the narrow pipes. The LLH decouples this from the primary, isolating the installer from any potential warranty issues with the boiler. A better solution is simply to have a sufficiently powerful pump in the first place, but of course most boilers and many ashps come with a pump included (which is normally powerful enough). This is another matter for your designer to get right - I would be looking for a solution where there was a single pump of sufficient power not two pumps and an LLH, and if that means restricting your choice to an ASHP that does not have a bundled pump then so be it. Alternatively it may be that changing a few selected lengths of pipework will suffice, again this does depend on the layout and crucially on the actual demand, which is why, in your particular case, a methodical approach by a knowledgeable designer is required. If you can deduce the pipe layout and in particular when pipes change sizes it will likely help.
Hope that helps.
* of course boilers aren't really 110% efficient, that would be impossible. the declared calorific value of gas doesn't include the latent heat of condensation which is recovered in condensing boilers, so is less than the energy that theoretically can be extracted.
- 2,523 Topics
- 58.7 K Posts
- 447 Online
- 6,802 Members
This looks like a practical solution 👍
By bobflux , 5 hours ago
It's a detached house with a fairly large split-level e...
By petch , 5 hours ago
Your installer may well be right. If the WC curve isnt...
By JamesPa , 6 hours ago
Same as many boilers, ovens washing machines and other ...
By JamesPa , 8 hours ago
3 X Pylontech US2000 Plus @ 2.4 Kw each = 7.2 Kw SoFa...
By vzm56n , 9 hours ago
So on this question of compressor longevity, I have a D...
By Optimistic Optimiser , 10 hours ago
Horizontal Hot Water Cylinders for ASHP with Energy Efficiency Rating 'A'
I looking to Have an ASHP installed in the near future....
By vzm56n , 10 hours ago
RE: Noisy Grant Aerona 3 13kW ASHP question
Here's a LibreOffice spreadsheet. I put the formula f...
By bobflux , 15 hours ago
I assumed you were joking here. Hence my joke about ...
By Batpred , 16 hours ago
Photos of cylinder cupboard and UFH manifold would be u...
By Travellingwave , 19 hours ago
It has been some time since I posted comments about Eco...
By Dwynwen , 1 day ago
Something big is coming to Renewable Heating Hub! Ove...
RE: A Single Voice for Heat Pumps, But Will It Finally Raise Industry Standards?
From what I’ve read, the Heat Pump Association UK is me...
By Jonatan , 2 days ago
Pylontech US5000 stores about 4.3 kWh accounting for in...
By bobflux , 2 days ago
Hi all, Just an update on where we are with the "Consta...
By DEdwards , 2 days ago
By giganto , 2 days ago
By benson , 3 days ago
By Jonatan , 3 days ago
