12kW Samsung gen 6 ...
17 Users
63 Reactions
70 K Views
(@craig1980)
20221128 181119
20221128 180951
Posted by: @craig1980
  • @derek-m I didn't set them back to 21 straight away and left them for a day. At night it was longer between but by the next day it was back to the same.
Had the indoor temperature changed? A further test would be to watch closely the operation of the wireless receivers for the thermostats when the system performs its short off - on cycle.
Also check that all the plug and socket connections on the circuit board are making good contact.
(@craig1980)
@derek-m no change in the indoor temperature. The lights on the receivers do not change when it cycles on and off.
Did you close the airing cupboard door overnight? The reason I ask is that sometimes equipment, and circuit boards, can suffer intermittent faults due to thermal expansion.
What water law settings are applied at the moment?
(@craig1980)
@derek-m the airing cupboard door is always shut. It doesn't get that warm in there.
Pics of the screen set up of water law.
Not sure if the set up with "floor" is correct. Whether it should be  FCU instead?
Also running -2 on the home screen which I'm led to believe is a short cut to adjusting a water law setting. Assuming the 31?
Screenshot 20221128 191334 Gallery
Screenshot 20221128 191340 Gallery
Screenshot 20221128 191615 Gallery
Screenshot 20221128 191607 Gallery
Screenshot 20221128 191629 Gallery
Screenshot 20221128 191347 Gallery
Screenshot 20221128 191618 Gallery
(@hughf)
@hughf
Yes, I've seen all the different diagrams in the manuals, but it doesn't tell one which is correct. Also I don't see the point in having two pumps to do the job that one pump should be able to do.
I’d go with the one from the Jule installation manual, as it’s a Jule cylinder/heatpump package. Now that we’ve seen some more photo’s you can clearly see that the hydraulics match what is shown I their manual exactly.
(@hughf)
Hi Hugh,
Do you know if the Samsung controller will still use WC when operating with the indoor temperature located within the controller?
I have a lot of time for Glyn Hudson over on YouTube who has just DIYd his 5kW Samsung install and has documented it with a decent video. From the comments I’ve been having with his, he says that the Samsung will still use WC when the wired controller is used as for measuring room temperature. I’ve asked him if the controller will also support load compensation and reduce the flow temperature when the room is approaching the target temp. Inversely, increasing the flow temp to recover quickly from a nighttime or away/holiday mode setback temperature.
He uses a single pump (with PWM control) on his setup but his primary pipe work is short.
(@hughf)
8E90DC97 F673 4F72 B83B 9F9B4B9D131C
(@craig1980)
@hughf thanks for looking in to this.
@craig1980
Let me have a read through the manual and decipher what some of the descriptions mean. I'll get back to you tomorrow.
(@craig1980)
Great, thanks. This is all very helpful
(@hughf)
Glyn has his 5kW Samsung wired/plumbed up with full monitoring, the data can be viewed at:
https://emoncms.org/samsung5kw
Single grundfos PWM pump, a heatpump cylinder with a 1m2 coil (the same cylinder I’ve got - they were cheap on eBay back in the summer), and radiators throughout.
Page 12 / 32
AI Chatbot Avatar
AI Engine
Talk to
Wattson:
AI Avatar
Welcome to Renewable Heating Hub! Ask me anything about heat pumps: how they work, running costs or even how to find installers in your area.
By using this chatbot, you agree to the recording and processing of your data by our website and the external services it might use (LLMs, vector databases, etc.).
