New Fogstar 15.5kWh upright solution
Just noticed Fogstar have a new upright solution (coming soon). Given that it's Grade A cells, battery heater, cell balancer and 8yr warranty at £2500 incl VAT, is there much point DIYing with a Seplos anymore (at least for single bank solutions)?
i noticed that earlier, i have already gone down the seplos 280L case path and so ordered another one now their BF sale is on. i would def have gone for the new one though - it has built in heater etc !!
I went for the upright seplos, mainly because they couldn’t tell me when these were coming in, and I’ve got two failing cells in my DIY pack. Need something asap.
Seplos should be here before Xmas.
I have went for and purchased this around Xmas.
Delivery has been confirmed for next week, looking forward to it arriving.
Regarding inverter and accessories - I purchased nothing as wanted to ensure it would arrive.
Anyone have a Inverter that works with Fogstar already? No solar @ my property..
Considering a Synsynk 5.5kW to run a house and a 10kW Aerona Heat Pump.
Any suggestions welcome.
@ggw congrats. Really looking to hear how it performs. Will you be installing it yourself?
Also, would love it of you considered reviewing it for the main site. Please let me know.
@ggw it works .... It does most if what I need but not sure how it would work for a 'geek' - I only wish it had a way to display the actual production from solar via the aux gen. I'm not really an app person but it seems ok. Really pleased with the Sunsynk inverter though, should have got an 8kw though ...but it doesn't affect what I get out of it!
PS I really like the new battery but I already had one Seplos so decided to get another to avoid potential conflicts. The new battery looks brilliant !
It's purely related to charging time periods. With 28.6kw of batteries, 6 hours on Intelligent Octopus will work, but any more batteries and it wouldn't. I won't charge or discharge fully so that gives me wriggle room, I can eat through 20+ KW each day in the winter, so if I increase battery storage, I might not be able to charge it overnight at 5kw per hour charging rate. An 8kw inverter would have just given me the opportunity to increase capacity.....
@misterb good info, I see your viewpoint not
I purchased the sunsynk 5kW - matches my use case and it's as much as I want to spend.
Now for accessories required-
This is the current list:
M8 eyelet battery cable +/- +lugs
DC Isolator (battery internally has MCB)
6mm2 cable for AC input
AC isolator
AC RCD ? (Unsure if required)
Comms Cable for BMS
Anything else?
- 22 Forums
- 2,086 Topics
- 46 K Posts
- 18 Online
- 3,377 Members
By ASHP-BOBBA , 4 hours ago
@scalextrix if your under unit heater is like our Myson...
By Judith , 6 hours ago
By benson , 7 hours ago
By Bart , 3 days ago
Here’s a little more technical detail/p>
By Judith , 3 days ago
By AF1 , 4 days ago
By Old_Scientist , 5 days ago
RE: Plate heat exchanger considerations
As far as I can tell my vented system would have a peak...
By Scalextrix , 6 days ago
RE: Air Changes per Hour - ACH and the MCS requirement
There have been a few discussions dotted around (e.g. I...
By Declan90 , 6 days ago
