[Sticky] Home energy storage & battery register
@toodles definitely sounds like similar aims. I was kind of forced into the batteries/solar because of the EV. You cannot get a tariff to adequately cover both ASHP and EV. I need to charge EV overnight but then was loosing the savings with ASHP during the day due to the higher day rate. The EV needs 30 - 35Kwh and ASHP on a typical 6C day needs about 26Kwh
If I did this renewables project again I would do the solar and batteries first to get a revenue stream going then add the other tech over time
Regards
Bivalent system containing:
4.1Kw Solar Panel Array
@technogeek We don’t drive any vehicles and with our poor sight (my wife is partially sighted and I am registered blind), it is better to keep death off the roads! Cosy seems to be the best deal without any EV’s but at least, with 3, 3 and 2 hours each day at the cheapest rates, the scheme can work well with a battery charged at those times. Regards, Toodles.
@toodles thankfully we have a range of tariffs to meet most people's needs. I am just one of those edge cases so require a little extra technology to make it financially viable.
The Missus has to replace her lease car in May and thankfully has chosen an Octopus Intelligent Go compatible model this time so happy days! 🤣
Regards
I've only just seen this thread, although I've only had eveything connected up for about 6 weeks.
I have a Fogstar 16kWh battery, 7.6kWp solar array and a Solis inverter.
So far it has all worked well and is nearly our electric bill already, but a 20 kWh battery would allow us to run all day from the battery even in a wet grey February.
Posted by: @technogeekIf I did this renewables project again I would do the solar and batteries first to get a revenue stream going then add the other tech over time
We managed to get a revenue stream just with the battery..
I have Solis 8Kw inverter and 2 * 16Kwh Fogstar batteries. No solar as yet. I have been on Intelligent Octopus Go since January this year and though almost doubling my Kwh use from last year my January bill was halved, and no gas of course.
Daikin 6Kw ASHP.
- 239 Online
@cathoderay yes that is it in a nutshell. I am keepin...
By benson , 45 seconds ago
By cathodeRay , 48 minutes ago
By Deltona , 2 hours ago
By JamesPa , 11 hours ago
By Bash , 12 hours ago
By Batpred , 13 hours ago
By cathodeRay , 13 hours ago
By Batpred , 14 hours ago
By DavidB , 16 hours ago
By Batpred , 17 hours ago
By Slartibartfast , 17 hours ago
By JamesPa , 19 hours ago
By Batpred , 19 hours ago
By Papahuhu , 20 hours ago
By Bash , 22 hours ago
By Odd_Lion , 22 hours ago
By RICHARDF5033 , 2 days ago
By Will H , 2 days ago
