Thanks for the information in this post, very helpful and informative.
I'm having solar panels installed today and tomorrow, with batteries, plus and ASHP and EV charger. We'll have 6.79kWp of solar panel capacity and 20.72kWh of battery capacity, 5kW of inverter capacity. We're just finishing a full renovation where we've had new windows throughout with very low U values, and we're finishing the project by adding 100mm of external insulation.
I'm very much a novice in this area so would welcome advice on the best tariff to start with our new system. I don't yet have a good feel, let alone data, on what our usage is going to be but i'm hoping that we can mostly use the solar and off-peak energy that we store in the batteries to keep our peak usage to a minimum.
Look forward to hearing your suggestions, thanks Nick
@nickmorgan what make/model charger & EV?
What rate can batteries be charged/discharged at?
If compatible I'd focus on Intelligent Go for imports and Flexible outgoing.
That should get most imports at 7p at night for car and fill battery.
Maximise exports at 15p. You can even force discharge batteries to add to income. There maybe a round trip loss but it czn be worthwhile.
I have ashp, solar, batteries, ev. I may be at extreme end but net cost of elec is probably nil this year!
13000kWh imports @ sub 8p
6500kWh exports @ 15p inc forced exports
Heat pump uses around 6000kWh
EV uses around 2000kwh
Solar produces around 7000kwh
LG Therma V 16kw ASHP
Underfloor heating + Rads
8kw pv solar
3 x 8.2kw GivEnergy batteries
Manual changeover EPS
MG4 EV
One other question, @nickmorgan. Do you have, or are you intending to have, some form of central automation system?
If yes, which do you have or are you considering?
If no, probably best not to concern yourself too much with Agile.
@majordennisbloodnok I haven't got to that yet, but am very open to suggestions for best options here too.
@nickmorgan hopefully that's compatible with Intelligent Go. Should be easy to check. Come back if not.
8kw pv solar
MG4 EV
Posted by: @nickmorgan@majordennisbloodnok I haven't got to that yet, but am very open to suggestions for best options here too.
I think at this point all that’s really important is whether you’re open to putting a bit of effort into pulling everything together into a cohesive system, and it sounds as if you are. Not everyone is comfortable with the familiarisation necessary, so I wouldn’t want to assume.
In which case, it’s more about deciding what you want to achieve and that means letting your plans bed in a bit. Better you choose your automation based on requirements than choose an automation system and try to find uses for it.
@majordennisbloodnok automation may partly be dictated by the infrastructure?
Make/model of ashp & inverter for starters?
8kw pv solar
MG4 EV
Posted by: @tim441@majordennisbloodnok automation may partly be dictated by the infrastructure?
Absolutely. That’s one of the reasons I wouldn’t want to make any suggestions yet.
@tim441 and @majordennisbloodnok We're installing Fox batteries and inverter. The 5kW inverter can output upto 5.5kW but only for 60s, typically it will be operating at a maximum of 5kW. The batteries have a recommend charge/discharge current of 30A of a nominal voltage of 179.2V, giving 5.37kW. And we've got a Grant Aerona 290 9KW ASHP (HPR2909 product code). Thanks again for your interest.
@nickmorgan I don't know best options for your scenario. But you could try ChatGPT. It's usually a good starting point but does not always get things right!
Try this and add more questions
https://chatgpt.com/s/t_68e67a78ab308191a858e17da27ebd6d
8kw pv solar
MG4 EV
With automation suggestions. Needs checking
https://chatgpt.com/s/t_68e67dd61724819184db3b6977cf50bf
8kw pv solar
MG4 EV
Poll for Time of Use, tariffs, technology
2 months ago
Our journey through Octopus tariffs 2020-2025
2 months ago
Automation options to maximuse efficiency & ToU tariffs
4 months ago
2 years ago
Octopus export - standard fixed tariff is 15p
3 years ago
- 2,475 Topics
- 56.9 K Posts
- 366 Online
- 6,165 Members
By errmm , 4 hours ago
By JamesPa , 5 hours ago
By JamesPa , 6 hours ago
By DavidB , 7 hours ago
By CraigH , 8 hours ago
By Rusty , 8 hours ago
By Mars , 8 hours ago
By AndrewJ , 9 hours ago
By Batpred , 11 hours ago
By Toodles , 11 hours ago
By Papahuhu , 12 hours ago
By Batpred , 13 hours ago
By Gruff2001 , 13 hours ago
By Steelbadger , 1 day ago
By Jancold , 1 day ago
By L2jad , 1 day ago
