New Build 3 Phase or 1Phase
Posted by: @bobfluxif you have a PV inverter and either sun or charged batteries, and the electricity provider is limited to 25kVA
Not so any more....
1: It's now the case that the Service Fuse will be 80A, not 100A.
Each DNO will have issued their own directive (known as a Standard Technique) which specifies this.
Read this one from National Grid (NGED).
For three phase domestic supplies, the Service Fuse will normally be 60A per phase for a domestic customer.
2: The "designated voltage" for 1ph is 230v. See sect.27 of the Electricity Safety Quality and Continuity regulations.
DNOs are now starting to change the taps at Primary substations in order to reduce the usual 240v we have grown used to.
This change has still not been fully ratified, but is agreed on by members of the Electrical Networks Association (ENA).
80A x 230v comes to 18.4kVA.
3: If your continuous loading is calculated to exceed 60A (not the 80A fuse rating), there are circumstances by which the DNO can require you to accept a 3ph supply.
The reasons are complex, but pay particular attention to the Neutral current and you'll begin to understand the issues.
The whole point of 3ph is that the load on those phases should be even.
That being so, no current flows in the Neutral.
Deliberately designing a supply for a new house which causes large currents in the neutral will create thermal stress at the local substation.
That causes breakdown of insulation, and hence a higher risk of outages.
4: If the reason you are applying for a single-phase supply greater than 18.4kW, but not more than 23kVA, is due to an EV charger, then it may not be fixed to the building.
The charger must be fixed to a separate/dedicated post, with the position dictated by airflow for cooling.
Talk with the Network Planner in the DNO Team assigned to your area.
They use a software calculator which takes into account a number of parameters which you won't know about.
- 2,817 Topics
- 66.8 K Posts
- 2,616 Online
- 7,231 Members
They pay for the running cost of the heat pump, and wit...
By RobS , 4 hours ago
I couldn't agree more. It's all to easy to get wrapped ...
By Majordennisbloodnok , 9 hours ago
By hml1827 , 10 hours ago
By Mars , 13 hours ago
By bobflux , 14 hours ago
By EtchedPixels , 1 day ago
By Toodles , 1 day ago
By Chilli304 , 2 days ago
By JanHarley , 2 days ago
By bobflux , 2 days ago
