What a difference a...
What a difference a few degrees make.
2 Users
1 Reactions
Topic starter   [#3099]
With this prolonged spell of warm weather, the ground through which the mains water flows has warmed up considerably. I have noticed that the ‘cold water’ is now tepid and decided to check the temperature; our main is flowing in at ~26.5 degrees C. this morning. This may go some way to explain how our daily DHW energy requirement has dropped to ~ 2.3 kWh when normally in the summer, it would be ~3 - 3.5 kWh per day. (This is using the Sunamp Thermino Epv 210 and servicing the needs of two persons.)  Regards, Toodles.
This topic was modified 4 months ago by Toodles
(@old_scientist)
Wow. Having accepted the challenge, I ran the cold tap for a good few minutes to pull through fresh water, and the temperature stabilised at 21.0C.
I don't recall what temperature I measured in winter, but think it may have been somewhere around 10-12C maybe.
At 26.5C, I wouldn't even bother heating the water - that sounds about the perfect temperature for a shower at the moment!
