Simple water tank thermostat with legionella cycle?
@mjr Yes, I read something similar. Basically if you can find out what burner nozzle is fitted and what the pump pressure is set to and when the burner is running then the oil consumption can be pretty well estimated. Then it’s just litres/h x 10.35 to get kw/h.
Posted by: @cycleneil@mjr Yes, I read something similar. Basically if you can find out what burner nozzle is fitted and what the pump pressure is set to and when the burner is running then the oil consumption can be pretty well estimated. Then it’s just litres/h x 10.35 to get kw/h.
What is it that you are trying to measure, the overall energy consumption, or just that for producing hot water?
- 2,122 Topics
- 46.6 K Posts
- 74 Online
- 4,529 Members
@terry1812 Yes, I use Homely, as to whether Daikin is u...
By Toodles , 2 hours ago
By cathodeRay , 7 hours ago
By Toodles , 11 hours ago
By Transparent , 13 hours ago
By Judith , 18 hours ago
By JulianC , 1 day ago
By Judith , 1 day ago
By TRBob , 3 days ago
By Transparent , 5 days ago
