27 Users
117 Reactions
25.1 K Views
(@andris)
@irmartini That looks great! What is your set up look like?
(@irmartini)
@andris
Its a 11.4 kW array
28x 400W panels
14x WSW (front)
14x ENE (Rear with shading so these panels have optimisers)
They feed 2x 5kW inverters (each has a 7x panel string from the front and rear so the inverters are balanced)
MPPT 13 44c
Does anyone else here actually monitor the incoming solar?
Or are you all happy to report what the inverter says it's handled?
I mention this because I had one inverter with a faulty MPPT input.
MPPT = Maximum Power Point Tracking
It would go through bouts of 'forgetting' how much current to draw from the panels.
Ie it was no longer able to find the knee of the curve where maximum power was achieved.
MPPTgraph
That resulted in a self-imposed reset.
The current dropped to zero, and the MPPT algorithm re-started.
This video clip shows two such MPPT resets in close succession.
I was probably losing 5% to 15% of power input to that particular inverter, depending on how many resets there were in a day.
This post was modified 5 months ago by Transparent
(@irmartini)
@transparent
I have no way of monitoring that or rather I don't know how to or what would be required to and so reply on what my inverters report.
However as they are new and so assuming they working fine so far, I have lots of graphs and totals right from install I would like to think I could spot an issue like that over time. (hopfully 🤔 )
Posted by: @transparent
Solely believe the SolarEdge app.
That's fine @irmartini and @editor
but let's keep this issue in mind for the future.
If we get someone arriving here on the Forum who says their inverter(s) are reporting less output than their solar arrays should be capable of,
then a faulty MPPT input port is a possibility.
In my case that inverter was new. 😥
A DC Energy-Meter like this costs about £10 from China incl VAT & shipping
or £23 from Amazon UK.
I can assist with installation guidance if anyone here wants it.
(@andris)
This will be a record month if it goes like this. Already at 484kw.
This post was modified 5 months ago by Andris
(@tim441)
Prominent Member Contributor
@andris I'll blame you for the clouds for next 2 weeks!
LG Therma V 16kw ASHP
Underfloor heating + Rads
8kw pv solar
3 x 8.2kw GivEnergy batteries
Manual changeover EPS
MG4 EV
3
(@andris)
@tim441 I know forecast doesn't look great.
(@old_scientist)
MPPT 13 44c
@transparent I have an Emlite ECA2 MID-approved meter fitted which records solar generation (available for around £40). The meter records slightly higher daily values than those reported by the inverter app.
This post was modified 5 months ago by Old_Scientist
(@ianmk13)
I have three  CT monitors on my solar output via the microinvertor controller, the Battery Management System (using a mid-approved meter) and my EV charger. They only roughly correlate with each other.  At the end of the day, though, it's only the electricity company's meter that matters.
Posted by: @old_scientist
I've looked up what that is.
It must be on the AC output of your inverter.
Having such a MID certified meter is a requirement for exporting to the grid.
But a meter on the inverter output would not have spotted the problem I'd discovered.
It only records what the inverter has successfully handled.
Page 12 / 17
