Thanks, @editor, will do.
For now, though, what I can say is that this December has seen us consuming around 580kWh with the coldest days (-2ish degC) running at around 21kWh. Overall the COP for the month was just over 3.5 and ranging from 2.5 on the coldest parts to about 4.5 during the milder bits.
It’s been a rubbish month for solar generation, but we’ve still managed about 30kWh since install on 15th, so a reasonable offset for the ASHP. Interestingly, though, the system has learned to be topping up the battery from the grid overnight, so pretty much all our consumption over Christmas has been night time prices with very little daytime power pulled in from the grid. That’s a big saving on its own.
I worked out that if every month this coming year was effectively another December weather-wise, we’d save about £400 against our previous oil consumption. The real savings when the warmer sunnier weather comes will be really interesting to see.
@setithing, sounds intriguing and I'd certainly like to hear more – please feel free to start a new thread and post your thoughts, ideas, visuals and diagrams. Full respect for thinking about DIYing this. Look forward to hearing more.
Introducing my self here. I am a London based installer of heating systems, and concerned that many well intentioned purchasers of heat pumps are missing out on optimum performance, of what is effectively state if the art heat pumps by mixing control strategies.
in fairness this is because of regulations that do not promote “seamless bundles” which offer easy optimisation
Professional installer
Posted by: @alec-morrowIntroducing my self here. I am a London based installer of heating systems, and concerned that many well intentioned purchasers of heat pumps are missing out on optimum performance, of what is effectively state if the art heat pumps by mixing control strategies.
Alec,
could you expand on what you mean regarding the control strategies and seamless bundles you mention?
@kev-m essential where the controls come from the same manufacturer as the heat pump, but with the proviso that the communication between the two is two way using bus language
Posted by: @alec-morrow@kev-m essential where the controls come from the same manufacturer as the heat pump, but with the proviso that the communication between the two is two way using bus language
Brendan, who used to frequent this forum, championed, I believe, a similar theory.
I’m in the process of changing mine and await delivery prior to instal. Recently had an LG Ecodan ASHP installed. The installers chose to control this with a Heatmiser Neostat Air V2. I now have the LG wifi room sensor and expect delivery of the LG wifi receiver hopefully next week. Is that what your post alludes to?
@morgan sorry it’s not a theory. A compensating controller will tell the heat pump or electronic mixer to lower flow temperature as target room temp rises
Posted by: @alec-morrow@morgan sorry it’s not a theory. A compensating controller will tell the heat pump or electronic mixer to lower flow temperature as target room temp rises
Well excuse me for the utterly unforgivable mistake of using a word in error 🙄
Please don’t concern yourself re answering a question. Have a nice day.
Posted by: @morganPosted by: @alec-morrow@kev-m essential where the controls come from the same manufacturer as the heat pump, but with the proviso that the communication between the two is two way using bus language
@kev-m i only mention this as it might be worth editing your post as quite often people search for specific manufacturers. It is not to catch you out i promise.
I think you meant Mitsubishi rather than LG?
Posted by: @jeffPosted by: @morganPosted by: @alec-morrow@kev-m essential where the controls come from the same manufacturer as the heat pump, but with the proviso that the communication between the two is two way using bus language
I did notice but it was @morgan's post, not mine.
Kev
Thank you for your input Alec.
I think that it has already been established that the equipment manufacturers automatic control system is superior to thermostats and the like. You need to educate the system designers and installers who insist on convincing customers to have the wrong equipment installed in the first place.
- 26 Online
By Tasos , 1 hour ago
By Mars , 2 hours ago
I couldn't agree more. This is a case where you buy as...
By JamesPa , 11 hours ago
By Scalextrix , 1 day ago
Inventor (Midea) Heat Pump short cycling advice
Hello, I have a Inventor (Midea) 8kW with a 800meters Φ...
By immunity , 1 day ago
By Old_Scientist , 1 day ago
By bontwoody , 2 days ago
By Alex , 2 days ago
By GrahamF , 2 days ago
By Morgan , 2 days ago
By DREI , 2 days ago
By Profzarkov , 2 days ago
By ASHP-BOBBA , 3 days ago
By DREI , 4 days ago
