Govt petition for review of EPC calculations to assist ASHP/GSHP
Does anyone know if a petition has been raised on the govt sire for this? If sh where is it? If not is anyone interested in assisting I need 5 people and email addresses to start one. It is important that if the Govt want to increase the number of heat pumps installed then they need to ensure that the british regs are adjusted to allow for the unique way that heat pumps work, at present i am loosing points and just sitting below a c rating because I don't want TRVs on my system and simply to run it on weather compensation big black mark on my EPC!!
i’ll join you.
Heat pumps aren’t special, they are just another heat source for a heating system
boiler manufacturers use the same compensation controller on boilers as heat pumps or both
Professional installer
Posted by: @alec-morrowi’ll join you.
Hi Alec,
I'm afraid that I have to disagree. Because ASHP's in particular obtain 2/3 or more of their energy source from the outside air, their efficiency is severely affected when the outside air temperature is low. Basically the calorific value of the energy source is reduced at precisely the time when they need to work harder. It is therefore much more important for a heat pump to be correctly configured than any other boiler type.
@derek-m that doesn’t change the control strategy to put a heating system in a stable state (room temp)
The heat pump performance will be set and unalterable to accommodate the change in climatic conditions. All you can change is effectively a demanded temperature from the controller.
The system controls need to be adjusted to accommodate the building and other variables such as embitter type. These variables don’t change according to heat source.
Condensing boilers increase efficiency with lower flow temperatures, but the heating system demands the same temperature what ever the heat generator there are even electric resistant heating boilers which vary flow temperature with no efficiency gain, but because the building is held at a fixed temperature there is a saving in electricity usage, albeit probably not much
- 22 Forums
- 2,057 Topics
- 44.9 K Posts
- 42 Online
- 3,298 Members
RE: Heat Pump Manufacturers Recommending Buffer Tanks
One manufacturer Viessmann has to have their buffer, as...
By Johnmo , 46 minutes ago
RE: Is Your 6kW Air Source Heat Pump Really a 6kW?
Sounds like your 6kW unit is really just an 8kW with a ...
By logansmith01 , 18 hours ago
RE: How To Balance Radiators & the Role of the Lockshield Valve: A Homeowner's Guide
Good luck, I hope it all works out!
By JamesPa , 19 hours ago
@johnd it's a difficult one, because we've seen instanc...
By Mars , 21 hours ago
RE: IVT Greenline high pressure switch and electrical cassette errors
Here are the reported most common causes for both. Co...
By abbote , 22 hours ago
@johnmo sorry it comes across like that. The post is au...
By KevinPotts , 22 hours ago
@johnmo Perhaps a little detail might explain my reason...
By Toodles , 22 hours ago
Win a 6-panel PV courtesy of egg and Renewable Heating Hub
Our epic giveaway just went live! Want to win a 6-pan...
RE: Yes, the "zoning with ASHP" topic again...
James, thanks again for your thoughtful and persistent ...
By HarryRea , 1 day ago
RE: Is this normal? Click of the DHW returning to space heating
So the Lone Ranger returned today! Even though we thoro...
RE: Vaillant & OVO partner up to offer Heat Pump Plus
Hopefully iv done the right thing today by signing up t...
By Westkent , 2 days ago
My own experience with connecting four batteries to thr...
RE: Plate heat exchanger considerations
Work on 2-3 percent per degree. This is a reasonable e...
RE: Advice for ground source heat pump in new build with PV and batteries
The useful bit is the bit that specifies the heat loss ...
RE: Volumisers in Heat Pump Systems: Does Placement Matter?
You’re absolutely right that during defrost the refrige...
@editor thanks Mars that’s the same table I found in th...
By Gary , 3 days ago
RE: Tariff and charging strategy advice please
They haven't asked me to prove that I have an EV (I do)...
Took a while to find on the OFGEN site: ”The FIT sche...
By AgentGeorge , 3 days ago
RE: why solar diverters for HW instead of the heat pump?
For me there are few factors why you may want to heat w...
By Johnmo , 3 days ago
