Reporting performance details again.
MCS installer predicted electric demand of 2130kWh to date from installation in April.
Actual consumption is 1442kWh.
So that’s a good start.
Perhaps I need to put more effort into measuring efficiency. But my quality measurement is Mrs Jules saying the home seems warm 👍
As stated earlier, I intend to run the system for a year using the Nest wall thermostat and then switch over to the Daikin controlled heat curve and compare.
35kWh yesterday. Average 30kWh per day in Dec
Average 19kWh/day in November.
And average 5.5kWh/day in October
Predicted was 13.8kWh in Oct, 31.6kWh in Nov and 50kWh/day in December. 54kWh/ day for January before it drops way
Warmer December so far means we are using less electric to heat home than predicted against MSC ASHP model. Namely 1638.11kWh consumed versus 2532kWh predicted. Good 👍
Posted by: @juliancWarmer December so far means we are using less electric to heat home than predicted against MSC ASHP model. Namely 1638.11kWh consumed versus 2532kWh predicted. Good 👍
You don't believe anything MCS says do you? 🙄
@derek-m haha Derek of course 😂
But it is a good way for me to track actual costs
Took out the gold level Daikin ASHP support contract today. £264/year for 10 years. Fixed price. Including annual service, free parts, labour and call outs. Added cost, over and above the ASHP installation. But I think piece of mind. One of the reasons I chose Daikin over other vendors.
How much do other owners pay for an annual service?
Hi @julianc
Happy New Year
It sounds like we are getting a similar set up to you - solar panels, Mixergy tank, Daikin heat pump and battery. In a previous house we had solar panels and a Mixergy tank and loved that set up. The battery seems to be a set and forget type of system, or at least easy to tweak through an app etc. The only component that I've no experience of is the Monobloc heat pump. I've done lots of homework, and am looking forward to having it, but I was wondering what your thoughts are on the actuality of living with your heat pump and the system overall. Does it just sit there and get on with it? Or do you need to tweak it a lot? I noticed that you needed to be sure that noise wasn't an issue - is that working out OK too?
Any pointers/thoughts would be great
Cheers
Alastair
@alastair Happy New Year. Similar systems (except your battery).
My Daikin ASHP is fit and forget really. We are doing a year using a Nest as the controller. I’ve set the heat to come on in the morning and gradually increase late in the day to 20.5C. Then off at night. Mixergy heats during my cheap Octopus night tariff. So I’m using the Daikin like the oil boiler it replaced. No tweaking.
So we’ve used much less electric than MCS predicted (but milder?). 1900kWh used vs 3100kWh predicted. And my wife says our home is warm. So result.
Once the trial year is up, I intend to switch to using the Daikin heat compensation curve. And do another comparison.
Was outside as my Daikin went into reverse/defrost cycle. Here is a photo of the start. And the steam/water vapour being cleared as the process nearer the end. Took 9 minutes. At 1 or 2 C. Home stayed warm. But COP must be impacted. I’d not really seen before.
- 2,114 Topics
- 46.4 K Posts
- 80 Online
- 3,410 Members
Ours arrived a couple of days ago as it happens and pla...
By benson , 55 minutes ago
By Brendon Uys , 4 hours ago
Is this just haze or something more?
We clocked this article back in July from the BBC about...
By Mars , 5 hours ago
By Burtis , 18 hours ago
By JamesPa , 19 hours ago
By Old_Scientist , 1 day ago
By trebor12345 , 1 day ago
By Lucia , 2 days ago
By Ashfp , 2 days ago
By Mars , 6 days ago
By Prunus , 6 days ago
By Transparent , 1 week ago
