What is the relationship between flow rate and system balancing?
I've been thinking about this over the last few days, following the latest Podcast where flow rates are discussed - this was mentioned in passing but not followed through unfortunately.
If the flow rate is critical, then how is that affected by balancing the system by turning up/down the LSVs? Or turning down the TRVs which could prevent any flow through the radiator? Does it require an adjustment to the flow rate to compensate or does that just unbalance the system again? What happens if the flow rate is negatively impacted - how do I tell?
Perhaps a heating engineer can discuss this in some detail. Incidentally, I have no access to my system's flow rate so I can neither see what the current value is nor change it. But the system does need balancing as upstairs is running 1.5=2.0c warmer than downstairs, and even downstairs room temps span 19.5 to 22.2c.
Im noit a heating engineer, but I will have a go anyway (I think you are overthinking a bit)
Posted by: @andrewjIf the flow rate is critical, then how is that affected by balancing the system by turning up/down the LSVs?
If you turn down all the LSVs then you will restrict the flow. If you turn some up and some down the main effect is to redistribute the flow (thats what you are trying to do). Overall you want the flow as unrestricted as possible consistent with the system being in balance. So at least one LSV (often the one furthest from the heat pump, unless that's a towel rail) should be fully open. Towel rail LSVs should, I believe, always be restricted otherwise its virtually a short circuit.
Posted by: @andrewjDoes it require an adjustment to the flow rate to compensate or does that just unbalance the system again?
Not normally. The water pump will just keep going, the flow rate may change a bit, DT may change a bit and the system will simply reach equilibrium at a slightly different point. Flow rate is critical, but only in the sense that it has to be high enough to transfer the energy required with a reasonable dt across the emitters, and not so high as to cause noise in the system. It doesnt have to be a precise figure.
Posted by: @andrewjWhat happens if the flow rate is negatively impacted - how do I tell?
Your heat pump will normally monitor flow rate, if it doesnt then you cant easily tell whats happening. Almost all, probably all, heat pumps will complain and stop working if the flow rate goes too low.
Posted by: @andrewjBut the system does need balancing as upstairs is running 1.5=2.0c warmer than downstairs, and even downstairs room temps span 19.5 to 22.2c.
There is an article on balancing radiators elsewhere on the forum https://renewableheatinghub.co.uk/radiator-balancing-lockshield-valve-guide/
- 2,283 Topics
- 51.1 K Posts
- 206 Online
- 5,944 Members
@jamespa It is very emotional week for many of us, I pe...
By ASHP-BOBBA , 21 seconds ago
RE: What is the relationship between flow rate and system balancing?
Im noit a heating engineer, but I will have a go anyway...
By JamesPa , 2 hours ago
I did check and I was subscribed, still am. Didn't rec...
By AndrewJ , 2 hours ago
@batpred But you can still claim on your credit card...
By Bash , 2 hours ago
RE: The Hidden Secret to a Successful Heat Pump: Pipe Size Matters
@colinc good luck with your project! UFH is the absolut...
By Judith , 3 hours ago
The answer must be on continental scale interconnects.....
By Batpred , 3 hours ago
RE: Grant 13kW Aerona3 - issues getting zones to temp
@crimson This youtube might be of help The narrato...
By IaAck , 3 hours ago
Our Government doesn't set oil prices (because we dont ...
By JamesPa , 4 hours ago
RE: Installer Fitted 9kW Instead of 11kW Heat Pump and Changed MCS Paperwork - What do I do?
@transparent, ooh, I'm going to go through the Retrofit...
By Mars , 18 hours ago
@hcas Just wondering if/where Ideal might be on your de...
By simonwig , 21 hours ago
RE: UFH downstairs and radiators upstairs balancing question
I wonder what the logic of this was, that will be the c...
@judith I haven't noticed any noise myself yet, nor my ...
By Eliuccio , 2 days ago
RE: Ecodan ASHP Low COP and Unstable Compressor Frequency
Thanks for the reply and the welcome ! Locat...
By lukewarmbath , 2 days ago
@ectoplasmosis Buderus is a subsidiary of the Bosch Gro...
By Steelbadger , 2 days ago
RE: Confusion over Octopus Tariffs
@agentgeorge I can’t recall when and the details but Co...
@technogeek Yep, the same here. Toodles.
RE: Maximising Home Automation: Integrating Octopus Energy & More
Thank you and I agree most people can stay clear of net...
RE: Faulty Clivet heat pump out of the box
@steveimpey glad you got it sorted and agreed- being ig...
By benson , 2 days ago
@agentgeorge it has got 2, the other bleed screw is the...
By AdamK , 3 days ago
