Weather compensation climatic heat curves
We have a Grant Aerona3 R32 installed 3 years ago by a previous house owner hence we were not involved in the installation and are trying to work things out now. I have checked the install and weather compensation is enabled but I am a bit surprised at the heat curve settings and am looking for advice. The Maximum outgoing water temperature in Heating mode is set to 50C (Tm1), the Minimum outgoing water temperature in Heating mode (Tm2) is set to 45C, the Minimum outdoor air temperature corresponding to maximum outgoing water temperature (Te1) is set to -4C and Maximum outdoor air temperature corresponding to maximum outgoing water temperature (Te2) is set to 20C. To me, that is not much of a curve.... I appreciate this varies between installations. Unfortunately I have not been supplied with the heat loss calculations for the property but am trying to get it. It is an old house but reasonably well insulated. We live in the north of Scotland on the Black Isle, beside the sea, north of Inverness and aim for an indoor temperature of 18.5C
I think you assessment is correct. I would try and reduce the 45C end initially and see how the house feels.
Also 20C OAT is quite a high setting particularly if you prefer 18.5 inside. I would knock that down a couple of degrees too.
It’s a bit trial and error really to get the result that suits you. Just make small changes and see how that feels to get the lowest flow temperature you find comfortable.
10kWh DC coupled battery
Those settings are crazy and barely do any weather compensation at all. Perhaps they were set up by someone who thought that the radiators had to feel hot to be heating the house.
If your target IAT is 18.5 Id start with the WC curve at something like 30 (FT) (or even less - maybe 27 or even 25) at 15 (OAT). I would then slowly reduce the 'cold' end of the curve until your house just heats up enough. Once the cold end is set up you can tweak the warm end a bit later in the season.
Make sure that any external controls are permanently calling for heat. This means turning up thermostats/TRVs to well above the desired point, and ensuring heating is timed to come on 24*7 except when the system is heating DHW.
That should get you to a near optimum setting. Allow a couple of weeks, you can make bigger changes at first but once you are getting near change by only a degree every 24hrs.
Many thanks for that advice. I did think it was a bit crazy. The previous owners would not made these settings as they were in their 80s....
I have implemented and will report back...
There is one other setting in the Grant heat curve group which is the Hysteresis of water set point in heating and the default is 8C. Am I right that this relates to the hysteresis of the hot water tank heating and not the central heating and says that the hot water will come on if the hot water tank heating will come on when programmed if the tank is 37C and switch off at 52C as the tank is set to 45C?
I realise now that this hysterisis setting is controlling when the heating comes on e.g. Heating : Outgoing water temp ≥ Water set point (parameter 2100~2105) – Hysteresis (parameter 2141)
@jamespa thanks for the advice. If I am tweaking the curve for low temps, should I first increase the Maximum outgoing water temperature in Heating mode (currently 45c) (Tm1) or the Minimum outdoor air temperature corresponding to maximum outgoing water temperature (Te1) - currently -4C. Maybe Tm1 to 45C or Te1 to -1C??
To tweak for low temps I would increase or decrease (as appropriate) the target flow temperature at the minimum outdoor temperature end of the curve.
- 2,775 Topics
- 65.4 K Posts
- 2,330 Online
- 7,180 Members
By tomasmcguinness , 1 hour ago
@mrkfm, I'd also suggest that whenever you're ready, st...
By Mars , 13 hours ago
I'd rather be like this, than answering all th...
By Singlespeed , 14 hours ago
RE: Are you planning to use a wood burner to supplement your central heating this winter?
I use my stove daily for backup and comfort. Definitely...
By Margarethomas , 18 hours ago
@rob-of-york Thanks. I wish I'd started on this site as...
By mrkfm , 20 hours ago
This just might need a rebuttal (possibly marginally mo...
By cathodeRay , 22 hours ago
@downfield I just checked this morning and OE just r...
By Papahuhu , 23 hours ago
Thanks Will. I'll probably be a week or so before get...
By Singlespeed , 2 days ago
From experience this summer, a single-split A2A unit on...
By Rob of York , 2 days ago
Analysis of the economics of switching to an A2W ASHP compared to other heat sources
This post aims to analyse the economics of installing, ...
By Rob of York , 3 days ago
@editor does that mean you have to have two separate ex...
By mrkfm , 3 days ago
Posted by: @ian-s Could always use the money saved o...
By Rob of York , 4 days ago
Depends on what controls the pump! Thats the whole poi...
By Mars , 5 days ago
