Warmflow ASHP costi...
Warmflow ASHP costing a fortune to run and ignored by installer
8 Users
6 Reactions
13.9 K Views
(@myanthony)
951D89FF 9B36 41E5 BF45 F2F741329ADA
DDAE52EE 7F52 48CB 8EC0 1498E29FCC00
0A7543CA E290 44F7 85DC 02F25A0A71D1
69096DAB BA87 40B9 9FBE 23F06DF0B96F
C0749CE8 123B 4BBC 8CCB EE4FAE919337
(@hughf)
£10 says there isn’t one
@myanthony
The pipe with the isolation valve with the blue handle, to what equipment does the pipe connect?
(@hughf)
6230 F675E15F E514 410B 9AF6 43BF822DCD38
(@myanthony)
@derek-m I’m sure that’s for old biomass connection.
(@hughf)
Can you send more detailed photos of the outside of the cylinder? I'm suspecting that it might be a thermal store...
Posted by: @myanthony
There would appear to be two electrically operated valves, is that correct?
Does the flow pipe from the heat pump connect between these two valves?
@myanthony
It would appear that Hugh wishes to help, so rather than have too many 'cooks', I will leave you in his capable hands.
Best of luck in resolving your problems.
(@hughf)
@myanthony
Cheers Derek 🤣 Just what I needed...
You are more than welcome.
I prefer to work through problems in a systematic and logical manner, particularly when the person seeking help is new to heat pumps. I suspect that having a number of forum members throwing different questions at them could actually be counterproductive.
(@hughf)
It's going to be a difficult one to diagnose just off photos... I suspect that the ashp is batch charging the thermal store - that all needs re-plumbing if it ever stands a chance of working properly. Shame I'm basically the other end of the country.
This is one of the problems, you are arriving at conclusions without establishing the full facts.
Page 6 / 7
