Warmflow ASHP costi...
Warmflow ASHP costing a fortune to run and ignored by installer
8 Users
6 Reactions
13.9 K Views
@myanthony, it's a horrible task trying to find something you don't know what it looks like and where it could be. Ours (as you saw in the video) was actually inside the heat pump unit so we needed to remove side panels to get it in. We then had it moved indoors for a much easier cleaning experience.
(@myanthony)
@editor yes we opened panels but it was just loads of wires I’ll pass on all Info he might know what Y filter is or where to find I think he’s just scared to break it
(@hughf)
I can't see one anywhere in that internal pipework, and there won't be one under the external lagging...
(@myanthony)
@hughf thanks I pulled back lagging doesn’t look like that should be opened
D8706648 B2EE 4DBA 8B3A 53AEBC85596E
 haha
(@myanthony)
57125175 B1AA 4B28 B513 75403B90759B
094C1AE5 A538 4887 8722 E0CC73826E28
These are filters inside I tried the silver one other week and it was clear don’t know if these stop flow though
@myanthony
The 'Y' strainer should be in the return pipework probably just through the wall inside your home.
(@myanthony)
@derek-m ok thanks I’ve no idea how they down that as old biomass is there I’ll have a look thank you
@myanthony
The 'Y' strainer is not that large and could have been lagged over. If you feel along the insulation for any bumps, or if you find anything sticking out of the insulation then post a photo.
It would also be useful if you could check along both the flow and return pipework and if you find anything that is not insulated then post a close-up photo so that it can be identified.
Are you certain that any electrically operated valves are fully open?
That is a good point. Our UFH Honeywell valve died two years ago leading to cold zones. It wasn't responsible for the flow errors, but worth checking.
Valve
(@myanthony)
This is what’s coming inside
(@myanthony)
(@myanthony)
These two look like the only pipes that could release any water/blockage?
Page 5 / 7
