Vaillant aroTherm Plus 10kW thoughts?
Hi,
Any thoughts on this (larger) heat pump? Was main recommendation from a local heat Geek and certainly seems like a solid unit. The 7kw model is too small for the heat loss.
I guess my main thoughts are around noise for this twin fan unit and also if the 2 fans help or hinder defrost cycles?
It will be outside a kitchen window so noise a worry though no bedroom has a window facing it.
Thanks!!
If you need the larger one then you don’t get a choice!
BUT there plenty of well informed people who prefer the 10kW version. It’s quieter because its two fans run slower.
Defrost cycles need extra power so the 10kW is best for that too.
Posted by: @judithIf you need the larger one then you don’t get a choice!
@realevil Fwiw I have the 7kW model with which I'm, very happy. There is a 'warts and all' review on this forum, written by me.
It's not perfect, but I don't know of a perfect machine at the current tine. However it's pretty good on all major measures and has a good control system, much better than many competitors, as well as performing well. If I were buying again, I would buy another Vaillant.
@realevil the fans and fan speed / coil size (height, width and passes) are relevant to the capacity it is only taller due to being a 10kW, it is very unlikely to be any noisier due to having 2 fans, if anything it probably quieter but you can find this out and ask for the data sheet , Ecodan do the smaller single fan at 11.2kW but has more passes on the coil and again is quiet. The Vaillant is a very good machine.
- 425 Online
By cathodeRay , 20 minutes ago
I cannot see the complete rcbo, since the photo is cut....
By Batpred , 33 minutes ago
By Batpred , 43 minutes ago
By Batpred , 53 minutes ago
By cathodeRay , 1 hour ago
By AndrewJ , 1 hour ago
By benson , 3 hours ago
By Batpred , 7 hours ago
By GC61 , 8 hours ago
By JamesPa , 23 hours ago
By DavidB , 1 day ago
By Slartibartfast , 1 day ago
