Samsung / Worldheat...
Samsung / Worldheat buffer mixing
5 Users
8 Reactions
@davidalgarve Do you have fan coil radiators then? Toodles.
Posted by: @davidalgarve
Oh Crikey! I was hoping I had persuaded my reluctant contractor to change my tank to a volumiser in the return line, as advised by one of the contributors here
Apologies, this was the first time I had heard an argument for putting it in the flow, and the arguments for putting it in the return seem (and I think remain) sound.
However I will readily concede that @heacol s arguments for putting it in the flow are also sound and, since comfort trumps efficiency, arguably stronger.
That said I also agree amputation is also a very good approach.
Don't get too stressed, any of the above should be much better than what you currently have and it's unlikely that the difference between the three options is great.
Every day is a school day!
This post was modified 1 year ago 3 times by JamesPa
(@davidalgarve)
Posted by: @toodles
No, Just the usual for here, Roca segmental aluminium type.
That lets me off the hook then?
2 x Growatt 7.5kW Batteries
Fronius EV Charger
Kia e- Niro 64kW
@davidalgarve From what is written above, ‘amputation’ is probably your best option! Toodles.
Posted by: @toodles
How frequently do you get defrost cycles (I ask because if the answer is not very, it really doesn't matter).
(@davidalgarve)
Hardly ever, but started on the weather compensation path last winter and was fiddling with that up to spring this year so ever changing scene. Also added DWH about then and solar PV in August, so fragmented learning curve.
I will stick to the argument I put forward with my contractor
Fronius EV Charger
Kia e- Niro 64kW
Page 2 / 2
