@ecobaker Thats correct, I made the mistake of getting the same pump, but then decided to to sell it on ebay and get the UPM3 FLEX AS 25-75 130 AZA also on ebay.
@heacol easily resolved with a jumper wire on the end of the flow sensor cable 🤣
When I was commissioning my Sprsun I could not get the air out, kept tripping on a flow sensor issue. Jumpered the flow sensor out and left it at that. Haven’t seen a flow error since then 🤣 Got the air out eventually.
@heacol 👍
If the HP can't modulate below flow temp of 45 degrees and I'm aiming for flow temps of 35, is there much point in swapping out for a different pump?
Samsung Gen6 8kw ASHP in a two bed victorian mid terrace.
@ecobaker probably not
@ecobaker Probably not if the unit cant modulate at 35C. Maybe @Iancalderbank can advise if it works as low as that as i havent run mine that low yet.
I managed to talk to Glyn Hudson who was having difficulties getting PWM to work with his Samsung. However he has managed to sort it with a firmware update of the indoor controller and now it works at low flow temperatures, so it seems Samsung have sorted it.
https://community.openenergymonitor.org/t/samsung-mim-c02n-s-net-pro-dongle/25418/5
@bontwoody it will run at 35, but only stably if you have enough emitters to balance the min output of the HP. Which in my case with a 16kw gen6 unit is 3.5kw. Below about 34-35C my emitter output drops too low , so it would short cycles , so I have tuned the WC so it doesn't go much below that.
lots of run data on my heatpumpmonitor.org data, as per my sig.
@iancalderbank Thanks Ian.
@bontwoody @iancalderbank Thanks for the advice. Looks like Ill try and get a firmware update before removing the LLH, although that could be tricky.
Also I just swapped out a small radiator for a much bigger one in my kitchen which resulted in a jump of daily COP from 3.6 to 4.1, I have three other rads I want to swap as well when I can afford to do it. I think thats probably a first step before removing a LLH or changing pump.
@ecobaker mine did not need a firmware change. the PWM worked first time. I am not even sure how you would go about getting a firmware change done.
radiator changes - yes - put your effort in there first. obvious gains as you have found.
definitely. Bigger rads and lower flow temperature is your low hanging fruit.
- 23 Forums
- 2,098 Topics
- 46.2 K Posts
- 82 Online
- 3,385 Members
@jamespa Thank you! As soon as it stops raining I will ...
By skyefarmer , 1 hour ago
By Mars , 3 hours ago
@anca1808 I have just reviewed the whole thread. In s...
By JamesPa , 5 hours ago
By JamesPa , 16 hours ago
By Damon Blakemore , 23 hours ago
By downfield , 2 days ago
By Sune , 2 days ago
By Aventus Eco , 4 days ago
By Tim441 , 4 days ago
